Emerson EWD2202 dvd/vcr combo
Robotnik
A friend asked me if I could fix this thing... I said not likeley, but I'd
give it a shot.
The problem is in the DVD portion, not the vcr.
If you put a Disc in, CD or DVD ( tried both), display shows "load" it spins
up, the lense mechanics try to focus and what not, spins down, and repeats
this maybe 5 times or so, then gives up, and finally displays "-----" on
it's internal display. IF you don't put a disc in, but still eject the tray
and close it back, it very quickly displays "-----". This makes me think
that the laser is at least working.
She did not tell me if it was a gradual problem, or if one time it just
suddenly did not work, with no warning sings. I tried to clean the lense,
other than that, I don't know much else to do. IT looked pretty clean
inside actually.
My hunch is, some component failed that is virtually impossible for me to
find without some sort of diagnostic equipment, or by replacing parts one by
one untill it works again.
Any Ideas on this?
Thanks in advance.
Nic
K
Ken Taylor
give it a shot.
inside actually.
Any Ideas on this?
Thanks in advance.
Nic
Laser. Buy a new DVD if it isn't under warranty.
Ken
W
webhardy
Robotnik said:
Thanks, that's kinda what I figured.
I've had 3 of these P.O.S. things in the past 6 months.....went cheap
to save some money and every single one of them has crapped out the
exact same way just like you explained. I still don't have a fix so
if you've found something or know how to reset the machine, etc,...I'd
love to hear it. Otherwise, I've got $360 in Emerson paper weights.
Robotnik
This thing wasn't mine..... how long were the warrenties on yours?
Maxx Pollare
The voice of "webhardy" drifted in on the cyber-winds,
from the sea of virtual chaos...
Went cheap to save some money and every single one of them has
crapped out the exact same way just like you explained.
When cheap here too...
But I was far more fortunate on the DVD front.
I still had a good VCR, a Sharp I bought used in 1997, so all I was
looking for was a cheap DVD. So when Superstore had the Citizen
JDVD3830 on sale for $50can last Xmas season I grabbed two; one for
myself and one for my brother-In-law. I've seen a least two other
"repackaged models" with identical specs, features, & design at around
$40 this year, but with a different name branding.
It's a nice little unit...
Plays DVDs, CDs & MP3s well enough (no ID3, 8.3 file names). I haven't
had any luck getting it to play VCDs, AFAIK it only supports an early
version of that spec. It has most of the features you'd expect from a
DVD, but the button layout on the remote is a little cumbersome, as is
the onscreen display for MP3 playback.
About the only issue is the annoying power button.
The power button on the remote puts the unit in "sleep mode", indicated
by all three colour LED being on. But to actually turn it off you have
to use the front power switch, which acts like the rear power switch of
a computer; complete power off... }:8P
