ESP32-Based OpenWeather API Weather Station
CETECH1
Mar 18, 2023
57
With the rise of IoT applications, building a weather station using an ESP32 microcontroller is both practical and exciting. By leveraging OpenWeather's API, we can fetch real-time weather data and display it on the terminal. This project is perfect for beginners and experienced IoT and embedded systems developers.
Materials Required
Before starting, ensure you have the following components:
  • ESP32 Development Board
Setting Up OpenWeather API
  • Create an account on OpenWeather (OpenWeather Website).
  • Generate an API Key to retrieve weather data.
  • Choose API Endpoints (Current weather or forecast) and note the required JSON format
Installing Required Libraries
To handle API responses and display weather data, install the following libraries in the Arduino IDE:
  • ArduinoJson for parsing JSON data.
  • WiFiClientSecure for secure HTTPS communication.
Get PCBs for Your Projects Manufactured
You must check out PCBWAY for ordering PCBs online for cheap!
You get 10 good-quality PCBs manufactured and shipped to your doorstep for cheap. You will also get a discount on shipping on your first order. Upload your Gerber files onto PCBWAY to get them manufactured with good quality and quick turnaround time. PCBWay now could provide a complete product solution, from design to enclosure production. Check out their online Gerber viewer function. With reward points, you can get free stuff from their gift shop. Also, check out this useful blog on PCBWay Plugin for KiCad from here. Using this plugin, you can directly order PCBs in just one click after completing your design in KiCad.
ESP32 Code for Fetching Weather Data
Below is the ESP32 Arduino Sketch to retrieve weather data and display it via a serial terminal:
#include <WiFi.h>
#include <HTTPClient.h>
#include <Arduino_JSON.h>
const char* ssid = "";
const char* password = "";
// Your Domain name with URL path or IP address with path
String openWeatherMapApiKey = "";
// Replace with your country code and city
String city = "Coimbatore";
String countryCode = "IN";
// THE DEFAULT TIMER IS SET TO 10 SECONDS FOR TESTING PURPOSES
// For a final application, check the API call limits per hour/minute to avoid getting blocked/banned
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 10 seconds (10000)
unsigned long timerDelay = 10000;
String jsonBuffer;
void setup() {
Serial.begin(115200);
WiFi.begin(ssid, password);
Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP Address: ");
Serial.println(WiFi.localIP());
Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
void loop() {
// Send an HTTP GET request
if ((millis() - lastTime) > timerDelay) {
// Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey;
jsonBuffer = httpGETRequest(serverPath.c_str());
Serial.println(jsonBuffer);
JSONVar myObject = JSON.parse(jsonBuffer);
// JSON.typeof(jsonVar) can be used to get the type of the var
if (JSON.typeof(myObject) == "undefined") {
Serial.println("Parsing input failed!");
return;
Serial.print("JSON object = ");
Serial.println(myObject);
Serial.print("Temperature: ");
double a = myObject["main"]["temp"];
Serial.println(a/10);
Serial.print("Pressure: ");
Serial.println(myObject["main"]["pressure"]);
Serial.print("Humidity: ");
Serial.println(myObject["main"]["humidity"]);
Serial.print("Wind Speed: ");
Serial.println(myObject["wind"]["speed"]);
else {
Serial.println("WiFi Disconnected");
lastTime = millis();
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
http.begin(client, serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode>0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
Upload and Monitor:
Finally, connect the ESP32 to the system and select the correct port and the board, then upload the sketch.
Explanation
  • ESP32 connects to WiFi and sends an HTTPS request to OpenWeather API.
  • The response is in JSON format, parsed using ArduinoJson.
  • The ESP32 extracts key weather details (temperature & condition).
Optional Enhancements
  • Forecast Data: Modify the API request to fetch a 5-day forecast.
  • Web Server Dashboard: Convert ESP32 into a WiFi server to display weather in a browser.
  • Store API Data: Log weather readings to Firebase for historical tracking.
Conclusion
This ESP32-based OpenWeather API weather station allows real-time data retrieval with minimal hardware. Whether for home automation or IoT learning, this project is a great way to integrate API-based data retrieval into embedded systems.
