ESP8266: Able to flash but no program execution
Trior
Jul 22, 2023
3
Hi everyone,
I designed a PCB based on the ESP8266EX dotn here is the schematic:
To flash the board I use the module: https://joy-it.net/de/products/SBC-ESP8266-PROG I am able to flash the board with Arduino IDE with a simple code:
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
Serial.println("OK");
void loop() {
// put your main code here, to run repeatedly:
delay(1000);
Result of the flashing:
But when I open the serial monitor, nothing happens.
All the pins of the 8-pin connector are connected respectively to the Joy-it module.
Flash configuration :
  • Card Type: Generic ESP8266 Module"
  • Upload Speed: "57600
  • CPU Frequency: "160 MHz
  • Crystal Frequency: "40 MHz
  • Flash Size: "4MB (FS:3MB OTA:~512KB)"
  • Flash Mode: "DIO"
  • >Flash Frequency
I've tried different flash configurations without success.
I wonder if it's a connection problem between CHIP_EN and RST pin.
Flash datasheets: https://datasheet.lcsc.com/lcsc/2201121400_HTCSEMI-HT25WD40ARZ_C2928800.pdf
ESP8266EX datasheet: https://www.espressif.com/sites/default/files/documentation/0a-esp8266ex_datasheet_en.pdf
danadak
Feb 19, 2021
1,104
14,317
Have you put the switch on the programming module back to UART mode after programming and performed a reset of the module (unplug from the USB port and plug it back again)?
The ESP will not run with the switch in Prog mode.
Trior
Jul 22, 2023
3
Problem solved. I wasn't flashing esp in the right flash mode. It should have been flashed in DOUT mode.
