ESP8266 to google wifi router connection isn't working
Liran
Dec 9, 2017
4
Hi - does anyone know about a problem connecting ESP8266 to google wifi router? It doesn't connect no matter what i do. when I use tp-link router instead - the connection works fine.
by "connecting" i mean - it is programmed to connect to the routers SSID with the password. each router is using a different SSID (and i program each module to the correct ssid/password)
They can both operate at 2.4ghz so i can't see what's the cause.
google wifi:
https://www.cnet.com/products/google-wifi/review/
ESP8266:
https://www.ebay.com/itm/1PCS-ESP-0...834201&hash=item5d688652c3:g:TQEAAOSwFV9X0iVk
Ian
Administrator
Aug 23, 2006
1,486
Are you able to run a serial monitor and view the Wi-Fi connection logging from the ESP8266? Most of the libraries will output some sort of information whilst trying to establish a connection, so you may be able to find out a little more about the issue (i.e. is it an authentication issue, SSID not detected, etc...).
Are you using the same protocol on both routers - WPA2-PSK I presume?
