Experimental evidence for v > c in case of Coulomb interaction
W
Wolfgang G. Gasser
At least from a superficial point of view, there is a fundamental
difference between Coulomb interaction (Maxwell's first law) and
and electromagnetic radiation.
- In the case of e.m. transversal radiation (photons), conservation
of momentum and energy occurs on the one hand between emitter and
radiation, and on the other hand between radiation and receiver,
but not between emitter and receiver, i.e. there is no retroaction
of the receiver on the emitter.
- Yet the measurement of a Coulomb force is not possible without
a direct retroaction on the source of the Coulomb force.
- The action via radiation from an emitter to a receiver can be
switched on and off. The action can be stopped by deviating or
absorbing the radiation. All this is impossible in the case of
pure electric and magnetic interaction. (The only way to prevent
the action of electric or magnetic fields consists in creating
inverse fields, e.g. using a Faraday cage.)
Considering these fundamental differences, the fact that e.m.
radiation propagates at c cannot be taken for experimental
evidence that changes of the Coulomb field also propagate at c.
Because there doesn't seem to exist (convincing) experiments on
the propagation speed of Coulomb field changes in the literature,
I started almost two years ago my own experiments with a not too
expensive oscilloscope (Tektronix TDS2022, 200 MHz, 2 GHz).
The main problem of measuring the propagation speed of electric
field changes results from the fact, that a substantial amount of
charge must be displaced in the emitter in a very short time (in
order to entail a measurable field change at a given distance). Yet
charges move only at around 2/3 c (20 cm/ns). The more distant
from the emitter a measurement takes place, the longer the charges
must move so that the field changes become measurable. (The field
of an electrostatic dipole decreases with 1/d^3.)
Therefore, even under the hypothesis that electric fields are
instantaneous actions at a distance, it would be quite easy to
design experiments resulting in time delays (of a distant antenna
wrt a near antenna) in the order of t = d/(2/3 c) = 1.5 d/c.
Nevertheless, high-voltage discharges between two conducting
spheres (each 30 cm diameter in my case) leading to substantial
charge transfers seem to be a practicable way in order to get
convincing experiments.
_ _
_ _ / \
/ \ / \ >- \ _ _ _ _ _ _ _ /
\ _ / \ _ / _|_|_ \
|_____|
spheres with
spark gap antenna oscilloscope antenna
A simple influence machine is enough to generate high voltage
sparks leading to substantial charge displacements in short
periods of time. The spheres, the probes with the Coulomb antennas
and the oscilloscope are all placed in one line (where transversal
radiation from the spark, emitted rather perpendicularly to this
line, is negligible).
When charging the spheres, the Coulomb antennas connected to the
probes take the opposite charge of the nearby of the two spheres.
Because the charging of the spheres and antennas occurs slowly, the
currents and voltages are too weak to show up on the oscilloscope.
The discharge however is in the nano-second range. Thus enough
charge per time goes from the antennas to the oscilloscope so
that measurable single-shot signals can be triggered. The time
difference of the two signals can be compared on the screen of
the oscilloscope.
Precautions:
- The signals of each channel must not be influenced by the
presence of the antenna of the other channel.
- The signals must disappear or at least become weaker and delayed
(because of input capacitance loss) in the absence of the Coulomb
antenna (the probe itself is a weak Coulomb antenna).
- The two signals should be of similar order of magnitude.
I've tried several different setups. I also used a few times a
LeCroy, WaveRunner 6100A, DC-1GHz, which showed me that the results
are essentially the same as with my own oscilloscope.
According to my experiments, time differences between the signals
of the nearby and the distant antenna of t = d/2c can easily be
achieved, e.g. 4 ns in the case of a distance 2.4 m, thus clearly
suggesting faster-than-light propagation of the field changes from
the nearby to the distant antenna (light needs 8 ns for 2.4 m).
Because these are single-shot experiments, the results also suggest
FTL information transfer.
Cheers,
Wolfgang Gasser (2007-07-07)
__________________________________________________________________
ADDENDUM (2007-07-11):
More than three days have passed since I posted the above message
to sci.physics.research, but the moderators probably don't want
to direct their reader's attention to "the shame that such a basic
property of electromagnetism as the speed of propagation of the
Coulomb and magnetic potentials still has not been measured".
It would be great if someone could repeat the experiment. Even
better would be a replacement of the spark gap by a high voltage
thyristor or a set up with a powerful semiconductor nanosecond
pulser.
Surfer
_ _
_ _ / \
\ _ / \ _ / _|_|_ \
|_____|
spheres with
the oscilloscope.
Precautions:
Cheers,
pulser.
This will make you happy !
"Quantum electrodynamics and experiment demonstrate the non-retarded
nature of electrodynamical force fields"
J.H.Field
http://arxiv.org/abs/0706.1661
Abstract
"In quantum electrodynamics, the quantitatively most successful theory
in the history of science, intercharge forces obeying the inverse
square law are due to the exchange of space-like virtual photons. The
fundamental quantum process underlying applications as diverse as the
gyromagnetic ratio of the electron and electrical machinery is then
Moller scattering ee-ee . Analysis of the quantum amplitude for this
process shows that the corresponding intercharge force acts
instantaneously. This prediction has been verified in a recent
experiment."
The experiment he refers to is here:
"Experimental test on the applicability of the standard retardation
condition to bound magnetic fields"
A. L. Kholmetskii et. al.
Journal of Applied Physics -- 15 January 2007
http://scitation.aip.org/getabs/ser...00101000002023532000001&idtype=cvips&gifs=Yes
There is a related preprint here:
http://arxiv.org/abs/physics/0601084
Cheers,
Surfer
H
H. Wabnig
_ _
_ _ / \
\ _ / \ _ / _|_|_ \
|_____|
spheres with
This is the old and well known "standing wave" setup,
which makes you erroneously believe that you are smart.
w.
W
Wolfgang G. Gasser
= Wolfgang G. Gasser in news:[email protected]
= H. Wabnig in news:[email protected]
This may be the case, but using "standing waves" does not help
very much. A single-shot event such as a spark leading to a
substantial charge transfer is much more appropriate to measure
propagation speed. The oscillations emerging in the spheres
(the direction of the current in the spark can change) also
suggest instantaneity of the Coulomb interaction. But such
an 'apparent instantaneity' has already been found by Heinrich
Hertz before he succeeded to detect transversal radiation. See:
http://groups.google.com/group/sci.physics/msg/796c1b5a43a5ccde
See also:
http://groups.google.com/group/sci.astro/msg/0d70c727b10d88d6
"Suppose that a charge comes into existence for a period of time,
emits a Coulomb field, and then disappears. Suppose that a
distant charge interacts with this field, but is sufficiently
far from the first charge that by the time the field arrives the
first charge has already disappeared. The force exerted on the
second charge is only ascribable to the electric field: it
cannot be ascribed to the first charge, because this charge no
longer exists by the time the force is exerted. The electric
field clearly transmits energy and momentum between the two
charges."
This reasoning once again ignores the huge fundamental difference
between purely electric or purely magnetic interaction and e.m.
transversal radiation. A sudden disappearance of an emitter has
no influence at all on the radiation already emitted, nor has
the reception of radiation by a receiver any retroaction on the
emitter, becaue emitter and receiver are not linked by Newton's
third law. Also, the emitter of e.m. radiation loses energy, and
without an energy supply, the emitter cannot radiate (steadily).
Yet in the case of a charge, the field is independent of an
energy supply. Neither the charge nor its electr(ostat)ic field
can suddenly disappear*. A measurable effect on a second charge
is impossible without a retroeffect on the first charge, because
both charges are directly linked by Newton's third law.
"Let us now consider a moving charge. Such a charge is continually
emitting spherical waves in the scalar potential, and the
resulting wavefront pattern is sketched in Fig. 38. Clearly, the
wavefronts are more closely spaced in front of the charge than
they are behind it, suggesting that the electric field in front
is larger than the field behind."
Fig. 38 elegantly shows the violation of Gauss' law for electricity
(Maxwell's first equation) stating that the electric flux out of
any closed surface is proportional to the total charge enclosed
within the surface. Imagine spheres of different radiuses with the
charge at the center and integrate the flux out of them. See also:
http://tinyurl.com/2hbskq (Infinite electric flux paradox).
= Bilge in news:[email protected]
Sure it can.
Do you also take the fact that electromagnetic radiation can be
used to transfer information over huge distances for evidence that
the same can be done with purely electric fields?
Cheers, Wolfgang
* Nevertheless, it is possible to transfer an arbitrary amount of
charge over an arbitrary long distance in an arbitrarily short
period of time:
|o| |o| |o| |o| |o| |o| |o| |o| |o| |o| |o| |o| |o| |o| |o|
A series of pairs of plates are set up in a line. The plates of
each pair are connected by a thyristor 'o'. The opposite plates of
each pair are inversely charged. When all thyristors are switched
on at the same time, the electrons move from the negative plates
to the postive ones. The fact that a thyristor is a semi-conductor
device prevents the electrons from oscillating between the plates.
W
Wolfgang G. Gasser
= srp in news:[email protected]
This force is deemed to be acting between charges.
If you have a photon emitted by some electron moving inwards to
a location closer to its nucleus, it moves at c.
Agreed. Relativistic mass (resp. total energy) and momentum are
conserved, when the photon emerges: The atom suffers a recoil
impulse in the opposite direction and the atom also loses the
energy corresponding to the emerging photon.
See also:
http://groups.google.com/group/sci.physics.relativity/msg/08b57c2f826fd3e1
If it is
absorbed by some particle or atom not very close to the
emitting atom, then the force between emitter and receiver
will be infinitesimal at best.
I would say: there may be very small electric or magnetic
interactions between the emitting and the receiving atom
independent of the photon.
What's more, the force that
may be at play between emitter atom and receiver atom plays
no role with regards to the moving photon.
Agreed.
Once free, the photon is on its own, and will hit whatever
is its path, irrespective of the force that may be at play
between emitter atom and receiver atom.
Agreed.
My view on 'virtual photons':
http://groups.google.com/group/sci.physics.particle/msg/82a1aa7e869481ed
http://groups.google.com/group/sci.physics.relativity/msg/22280b0ba0da2c02
Jens Dierks in :
Das ist doch Unsinn, ob man ein "pures" elektrisches Feld hat,
ist beobachterabhängig.
Whether within special relativity the concept 'pure electric field
with respect to all observers' is nonsense or not is not relevant.
My question is an answer to Bilge who claims that the fact that
electromagnetic transversal radiation propagates at c can be taken
for experimental evidence that changes in the Coulomb field also
propagate at c.
Let us imagine two conducting tubes with a spark gap in between:
____________ ____________
\____________/ \____________/
If the voltage difference between the tubes exceeds a threshold
then a spark appears. At least if the conductivity of the spark
is high enough, charge starts oscillating between the tubes. But
whereas transversal radiation is maximum at a right angle to the
tubes (above-below in the the picture), the change in electric
field is maximum in the prolongation of the tubes (left-right).
So any attempt to deny a fundamental difference between transversal
radiation and the Coulomb field is doomed to failure.
And we must not forget that the asymmetries mentioned by Einstein
in his well-known first relativity paper
"It is known that Maxwell's electrodynamics -- as usually
understood at the present time -- when applied to moving bodies,
leads to asymmetries which do not appear to be inherent in the
phenomena. Take, for example, the reciprocal electrodynamic
action of a magnet and a conductor. The observable phenomenon
here depends only on the relative motion of the conductor and
the magnet, whereas the customary view draws a sharp distinction
between the two cases in which either the one or the other of
these bodies is in motion." (June, 1905)
http://www.fourmilab.ch/etexts/einstein/specrel/www/
do only arise if one takes seriously Maxwell's completely unfounded
claim to have demonstrated that all e.m. effects (even currents
in conductors!) propagate at c. If mutual induction is a direct
interaction-at-a-distance of magnet and conductor, depending on
their relative motion, then no difference in the "reciprocal
electrodynamic action" depending on whether "the one or the other
of these bodies is in motion" must be explained away.
Cheers, Wolfgang
W
Wolfgang G. Gasser
Wolfgang G. Gasser in :
I must admit that a result of on average of 4 ns instead of 8 ns
(corresponding to a propagation speed of c) is rather difficult
with a set-up sketched in my previous posting. Nevertheless, I
can achieve it with a set-up like this
_
_ _ _ _ / / _ _ _ _
/ \ / / / \ _ _ _ _ _ _ _ /
\ _ _ _ _ / \ _ / >- _|_|_ \
|_____|
where on both sides of the spark gap two spheres are linked by
aluminium foil in order to get something like a tube:
_ _ _ _ _ _ _ _ _ _
\ _ / \ _ / + _ _ _ _ --> \ _ _ _ _ /
The purpose of this setup is to prevent the currents from flowing
too soon in a direction opposite to the desired one and thus
contributing to a field change of opposite sign. This happens when
the first electrons after having passed the spark gap reach the
end of the sphere (resp. tube) opposite to the spark gap and from
then on start moving backwards.
In my last experiment I used such tubes (with aluminium foil
connections of 1 meter).
Setup of the experiment: http://tinyurl.com/yqa4hw/01.jpg
Influence machine and spark gap: http://tinyurl.com/yqa4hw/02.jpg
The distance from the spark gap to the unprotected end of one
probe is 2.75 m nearer than to the other end. (The distance
between the ends of the two antennas is even 3 m.)
According to the retardation hypothesis, the signal of the
distant antenna should be delayed by at least 2.75 m / c = 9 ns
with respect to the other signal. A typical screen shot of the
oscilloscope looks like this: http://tinyurl.com/yqa4hw/11.jpg
The bigger amplitude of the distant antenna after a few
oscillations results from its bigger capacity (there is more
charge participating in the oscillation). The length of the
nearby (funnel shaped) antenna is only around 4 cm, whereas
the other length is around 16 cm.
The oscillation period of short of 30 ns results from the time
a charge needs to perform a full oscillation on the emitter
system (i.e. from the spark gap to one end, then through the
spark to other end, and back to the spark gap).
If we change time per division from 25 ns to 10 ns and volts per
division to 10 V we get: http://tinyurl.com/yqa4hw/12.jpg
The interesting part however is the begin of the signal,
because it represents the arrival of the information that a
spark has occured: http://tinyurl.com/yqa4hw/13.jpg
I'd like know how such an outcome can be considered consistent
with the retardation hypothesis.
Cheers, Wolfgang
W
Wolfgang G. Gasser
= Tom Roberts in news:[email protected]
Tom, we had some very intersting discussions in the past, but
this reply of you has not much (relevant) content, and partially
it is not even clear. That you even criticize my use of 'action'
in a context of 'instantaneous interaction' and 'action-at-a-
distance' only shows how difficult it is for you to oppose my
arguments in a rational way.
And your pointing to the work of Heinrich Hertz shows that you
haven't read my second posting of this thread. Otherwise you should know that Heinreich Hertz
actually found evidence that the "electrostatic force" is
"propagated with infinite velocity". He found this not only in
the well-known experiment where he succeeded in generating
and detecting transversal radiation, but even before he succeeded
in doing that.
Whether you consider the undeniable differences between Coulomb
interaction and transversal radiation as 'fundamental' or not
is as (ir)relvant as whether you consider the difference between
e.g. men and women as 'fundamental'. Nevertheless, if a charge
oscillates on the x-axis around the the center of a coordinate
system, transversal radiation is maximum in y-z-plane whereas
Coulomb field changes are maximum on the x-axis.
... That is, you cannot detect the field without modifying it
(shades of quantum mechanics! -- but this is true in CLASSICAL
electrodynamics as well).
My point however is: You cannot detect the Coulomb field without
modifying the SOURCE of the field. Conservation of energy and
momentum is easily explainable in the case of the absorption of
photons by a receiver, because photons have energy and momentum
and all happens locally where the absorption occurs.
In the case of Coulomb interactions however, we have a non-local
exchange of energy and momentum between the source of a field
and a detector of the field. In my experiment, positive and
negatives charges of the emitter system and of the antennas
are directly linked by electr(ostat)ic attraction/repulsion.
You need to learn about grounding.
In the beginning, I made several errors with grounding. Once I
had even claimed to have detected instantaneous actions-at-a-
distance, before I had to learn that the synchronism of my
signals where not caused by the (too weak) Coulomb field changes,
but by the grounding current produced by the signal generator,
and distributed by the circuit of the domestic power supply
system up to the oscilloscope.
In my current experiments emitter and receiver are separated.
The signals do not only depend on the size of the antennas but
also on the distance from the emitter. So if your intention is
not only to discredit my results by spreading rumours, you
should specify what you mean.
= salmonegg in news:C2C2EA82.8A7BE%[email protected]
I would be more convinced if you measure over a length of 100 m
or more.
There is a huge potential in improving the experiment, but simply
increasing its dimensions doesn't help a lot, because the bigger
the distances are, the longer currents must flow (at 2/3 c) after
spark formation, before electric field changes become measurable.
Make the difference in propagation time large enough so
that random error is not casting doubt on your measurement.
Random errors are only a minor problem. The unpredictability
of sparks is a more serious problem. The problem with my
experiment mentioned here (and sketched above in my reply to
Tom) however is that a distance of 2.4 m between the receiving
antennas is rather too big for the emitter-system, where already
2.3 ns after spark formation, charge starts flowing backward to
the spark gap.
Another interesting experiment would be the measurement of the
propagation speed of mutual inductance using as an emitter a
solenoid (without core) of e.g. 1000 circular turns with each
a circumference of 20 cm, where each turn contains an electronic
circuit interrupter (e.g. a thyristor). If all 1000 turns are
interrupted within one nanosecond or shorter, then the original
magnetic field should disappear fast enough to induce mearurable
currents at big enough distances.
In any case, all less crucial physical experients should be
stopped until this open question is experimentally decided.
Cheers, Wolfgang
