Federal Pioneer Enclosed Switch 86311
oldtrout
Nov 30, 2015
Between the load screws the is a bar with 5 screws in it. I put a continuity tester on the load screw and the bar and they are not connected. What is this bar used for?\
shrtrnd
Jan 15, 2010
3,903
I guess we need to know more about the bar itself.
Are the five screws simply hold-down mounts for the bar itself?
I would suppose that's the reason for the electrical isolation from the bar.
Is there some other electrical connection to the bar, maybe even direct contact with electrical connections underneath the bar?
Minder
Apr 24, 2015
3,561
This is a bar for any neutrals that may be used, these are not switched.
M.
shrtrnd
Jan 15, 2010
3,903
Well then, Minder has the answer.
There is no continuity between the mounting screws and the bar, for isolation.
The bar is a common connection point for the neutrals.
