Arny Krueger
- Jan 1, 1970
- 0
Eeyore said:Why ?
Electronic devices seem to tend to have exponential characteristics.
Eeyore said:Why ?
in rather more moderate amounts to
a gain stage that's already quite linear.
When and where was this ?
And the spectrum is important.
Yes, as abused in the 70s, vast quantities of NFB were used in attempts to
correct significant non-linearities.
It seems to make a lot more sense to apply NFB in rather more moderate amounts to
Yes, but do you understand what I said, or are you just choosing to ignore
the difference between parallel circuits and series circuits?
distortion is hard to hear, particularly when listening to solo instruments.
This is due to concurrent spectral masking in the human ear.
Higher order harmonics are not so well masked as 2nd, so the ear can
pick them out, even when they are relatively small.
The audibility of harmonic distortion might also depend on tuning. In a
system using whole-number ratios, harmonic distortion of all orders might
be
less audible than in a tempered system.
That's not what I asked.
I aked if overall NFB can create 'new' harmonics, and it's now clear from
responses here that it can. I'm curious about the effect of local NFB in this
respect too. Does linearising a single gain stage with e.g. emitter degeneration
do the same ?
Mark said:Read the later posts.. I have conceeded the point.
It is an interesting observation but not very relevant to real world
audio amplifier circuits that are not ideal square law devices.
Why might that be?
William Sommerwerck said:Masking effects -- or lack thereof. For example, in such a system, the
third
harmonic would fall exactly on a scale note, whereas under our current
system, the third harmonic comes _very_ close, but not exactly.
This is speculation, of course. It's unlikely anyone has researched this.
William said:I first read this rule in the '60s.
William said:Neve Connecticut, USA. 1983, I think.
William said:The audibility of harmonic distortion might also depend on tuning. In a
system using whole-number ratios, harmonic distortion of all orders might be
William Sommerwerck wrote:
Bethel presumably? Did you ever meet Robin Porter.
I was told he'd spent some time at RN Inc.
Where did you originally come across it?
William said:Bethel, yes, right across from Mallory/Duracell.
The name doesn't ring a bell.
William said:In an "Electronics World" article about the new JBL solid-state amp with a
"T" output stage. The author explicitly stated the principle -- get the
circuit as linear and wideband as possible before applying feedback.
The spectrum is important, in fact it is critical. In many cases, 2nd order
