female 3.5mm to dual female RCA
Pasquale
I am trying to solder a female 3.5mm microphone jack to 2 RCA cables
(left and right), and I'm not sure how to wire it.
On the mic jack there is a tail and the 2 prongs (one silver and one
copper).
I have a white RCA cable (left) and red RCA cable (right). When I strip
the black shield there are copper strands and within the copper strands
there is a smaller shielded wire. The smaller wires are color coded to
correspond with the RCA jack color.
I tried soldering the copper strands of both RCA cables to the tail of
the mic jack, the small white wire to the silver prong and the small
red wire to the copper prong, which doesn't seem to work.
Can someone please explain how to wire this setup for what I need?
Thanks.
loedown
The easiest way to figure it out is like this
the 3.5 mm plug at the tip will have 3 distinct sections, seperated by
plastic between them
http://www.vandenhul.com/artpap/wiring.htm half way down the page
the two braid from the wires to the RCA plugs are connected together and
then connected to the sleeve of the 3.5 mm plug.
The thin white wire is connected to the tip of the 3.5 mm plug
The thin red wire is connected to the ring of the 3.5 mm plug
Paul
Chris W
Paul
Be a little bit careful here. If the microphone (3.5mm)plug is to be
plugged into the PC soundcard Mic jack, then one of the wires will be a
Bias voltage to power an electret mic.
Chris
loedown
No mention of PC, just the straightforward connection
Paul
Pasquale
Thanks for the info loedown. It works. I had wired that way already, but
I guess for what I'm doing I require a pre-amp.
I'm not connecting to a PC.
Pasquale
I forgot to mention my set up was actually a female 3.5mm not a male.
Roger Johansson
It works the same, no matter if it is a male or female.
You have connected it correctly, something else is the problem, like
lacking a preamp, as you say.
Pasquale
Thanks Roger.
I am now using a Stereo Pre-Amp and I am getting a little bit of signal
noise. Is there something you or anyone can suggest to reduce it?
Thanks.
Roger Johansson
You have not told us what you are trying to connect to what, you only
told us about a connector.
We need more details to be able to help you more.
Pasquale
My connection is a microphone into a small stereo pre-amp, out to a DV
camcorder. How can I reduce or get rid of the little bit of signal noise?
Pasquale
My set up is a microphone connected to the adaptor I made with the 3.5mm
female jack and dual female RCA's into a small stereo pre-amp via an RCA
cable, out to a DV camcorder.
Pasquale
cable, out to a DV camcorder using the RCA to 3.5mm cable supplied with
the camcorder.
Roger Johansson
3.5mm female jack and dual female RCA's into a small stereo pre-amp via
an RCA cable, out to a DV camcorder using the RCA to 3.5mm cable
supplied with the camcorder.
It depends on exactly how much noise you have there.
It is impossible to get rid of all noise, you can only get it a lot lower
than the audio signal.
How much lower depends on the quality of the microphone and the preamp.
It could be the mic preamp which is to noisy. Is it a real mic preamp?
You should test the setup by singing into the mic, adjust levels for
optimum quality and check how much noise there is compared to the audio
signal. Can you hear the noise through the audio signal, is it at a disturbing level?
When you do not sing into the mic and turn amplification up to max you
will always hear noise, but that is not a normal way of using a
microphone.
There is a device called noise gate which blocks the noise from the
microphone when you are not using it.
Pasquale
I'll see where I can find a noise gate, any suggestions?
Also, is it true that a capacitor would reduce noise? If so, how would
it be done?
W
Walter Harley
Also, is it true that a capacitor would reduce noise? If so, how would it
be done?
You're throwing equipment at a problem when what you need to do is
understand the problem. That almost never works, and almost always costs
more than solving the problem the right way. A noise gate would cost you
more than getting the right kind of microphone and/or preamp. And anyway,
all it will do is reduce the noise when there is no signal; it will not do
anything about the situation when there is a signal. And no, a capacitor
will not reduce noise.
You still have not adequately described the problem you have. In
particular, please answer ALL of the following questions:
What is the microphone you are using?
What kind of connector does it have?
Do you have any reason to believe that it is intended as a general-purpose
microphone, or is it intended to mate with some particular piece of
equipment (that is, did it come as an accessory to some other piece of audio
gear such as a tape recorder)?
What is the camcorder you are using?
What audio inputs does it have? (It might have more than one - for
instance, it might have both line inputs and an auxiliary mic input.)
What kind of connectors does it use for its audio inputs?
Are they intended for line level or mic level signals, and if the latter, do
they provide DC supply voltage for an electret mic?
Most likely, your problem is that are trying to use an electret type mic,
which has a little preamp built into it, and it needs DC supply voltage to
be provided by whatever it's plugged into; and your camcorder inputs are
intended for line level signals rather than a mic. In this situation, a
preamp will not help unless it is intended for that sort of mic. But, based
on what you've said so far, there is no way to tell if that is actually the
problem. You need to answer the above questions and then people might be
able to help you.
Pasquale
see below...
I have a Universal Microphone with 1/4" jack and the adaptor to 3.5mm.
On the package it says it can be used with karaoke, camcorders, portable
stereos, etc.
Panasonic. Just purchased a couple of weeks ago. FYI... Model PV-GS200.
It has A/V in/out 3.5mm(?) jack. With the camera came a A/V cable with
video, and left and right RCA on one end and the 3.5mm plug on the
other. I am getting the video no problem. As for the audio, I am getting
sound, I just need it to be amplified.
I put together a adaptor cable to go from the 3.5mm microphone jack to
the dual RCA ends. I think it may be from here where I am getting the
static/hum/noise. It seems that if it is held right the noise is pretty
much gone. Maybe poor solder or bad connection to the tail of the
microphone jack (ground).
The way I did the soldering was:
- RCA white inner core wire to the silver tab of the mic jack
- RCA red inner core wire to the copper tab of the mic jack
- copper wire surrounding each are both solder to the tail of the mic jack
W
Walter Harley
Sounds like a mono microphone, and could be the kind that doesn't need an
external DC supply voltage. So that's good.
You say "jack". Do you mean "plug"? Jacks are female, plugs are male.
Are the plugs stereo or mono?
[The camcorder] has A/V in/out 3.5mm(?) jack. With the camera came a A/V
cable with video, and left and right RCA on one end and the 3.5mm plug on
the other. I am getting the video no problem. As for the audio, I am
getting sound, I just need it to be amplified.
That definitely sounds like a line-level input. So you do need some sort of
microphone preamp. You mentioned you were using a preamp; is it in fact a
microphone preamp? What kind? How are you connecting to it?
I put together a adaptor cable to go from the 3.5mm microphone jack to the
It sounds like the "mic jack" you're describing here is the 3.5mm jack into
which you're plugging the mic plug. Or am I confused? If I'm right, it
also sounds like you're describing a stereo 3.5mm jack.
Is the mic plug mono or stereo? If you're plugging a mono plug into a
stereo jack, you will have problems - at the least, one channel will be
missing. So, it sounds to me like you may not have this wired correctly.
But it does also sound like there's a soldering problem.
Are you somewhere near a Radio Shack, or a TV repair shop or something?
This sort of problem would take about one minute to diagnose and give you
the right answer, for someone who could actually see what you're talking
about. Trying to do it in text, with inaccurate terminology and incomplete
information, is going to be slow going.
W
Walter Harley
In case that was unclear:
Do the plugs have three contacts (tip, ring, sleeve) or just two (tip,
sleeve)?
Pasquale
Thanks for all your help. Comments below...
The reference above should have been "1/4 plug" instead of "1/4 jack".
The rest of my references are correct.
The pre-amp... "Permits use of a turntable with a magnetic stereo phono
cartridge with an amplifier not equipped with the appropriate connections."
I know its not meant for what I am trying, but I just need something
temporary. I will get the proper mic pre-amp after the holidays, when
the stores are back to normal hours.
http://www.radioshack.ca/estore/Pro...RadioShack&category=Turntable&product=4202111
I am connecting my mic to the adaptor I made and then to the input of
the pre-amp with RCA cable. Then out from the pre-amp to the camcorder
with the A/V cable.
You are correct.
The mic plug is mono. The mic jack on my adaptor is stereo. So, I'm just
losing a channel.
I used the link below that was given to me in a earlier response for wiring.
I'm going to buy another 3.5mm jack for my adaptor and do a better
soldering. Now that I take a closer look at it, it's not so great.
Thinking about, I remember the tabs getting too hot because the tabs
were moving back-and-forth in the plastic core. I'm going to be more
careful this time.
Hopefully that will fix the problem. If not I'll try a repair shop or
Radio Shack and see what they have to say.
Thanks again.
