W
Walter Harley
- Jan 1, 1970
- 0
Pasquale said:I'm going to buy another 3.5mm jack for my adaptor and do a better
soldering. Now that I take a closer look at it, it's not so great.
Thinking about, I remember the tabs getting too hot because the tabs were
moving back-and-forth in the plastic core. I'm going to be more careful
this time.
Hopefully that will fix the problem. If not I'll try a repair shop or
Radio Shack and see what they have to say.
Based on everything you said - I suspect the problem is just a combination
of inappropriate preamp and defective soldering.
Rather than doing all this soldering, you might consider just purchasing
ready-made adapters. But don't do that until you have the mic preamp,
because what you need will depend on the connectors on the preamp; if you
get the right thing you might not need any adapters at all.
I'm inferring the mic you have is something like the Philips/Magnavox
PM62080 "Universal Mic", as shown at
http://www.gemini-usa.com/a5/modelDetail.asp?PkgID=370080&User=GemAudioAccessories.
This mic has what we'd call a "high impedance unbalanced" output. That is
different than most professional mics, which use "low impedance balanced"
outputs. That means that a typical mic preamp will *NOT* work properly with
it. The giveaway is that most mic preamps have "XLR" (three-pin)
connectors, rather than 1/4" mono connectors. You could build an adapter
but it wouldn't get you anywhere, because the signal levels are different.
It is hard to find preamps for this kind of microphone. Your best bet is
probably going to be to find a consumer-grade "mic mixer", even though you
aren't actually mixing anything. For instance, an excellent choice would be
the Radio Shack 32-2056:
http://www.radioshack.com/product.asp?catalog_name=CTLG&product_id=32-2056.
This has 1/4" mono inputs for the mic (meaning it is intended for exactly
your kind of microphone); it has stereo RCA outputs, so you don't even need
to buy any adapters; and it can run on a 9V battery. It lists for $40. You
might also be able to find something like it cheaper somewhere else.
Another possibility would be to find a DJ mixer.
If any of that is unclear, let me know.
