N
N Cook
- Jan 1, 1970
- 0
14 switch and 2 pedal, midi output guitar pedal.
One pedal not working - hope its not the pic chip.
At the moment exploring the horrendous squeel from the pedals.
Seems that for neutral hold, ie stays where the foot angle was last , relies
on a steel sleeve inside then the moving and mount-steel plates, either
side, and a through-bolt with nylock nut supplying enough pressure to make
resistance to movement, as axle. But it is steel plate turning against steel
plate on either side of the pivot - urgh !
How to deal with the squeel, oil would loose the neutral or dead action ?
As an aside
Anyone know of a simple circuit for exercising/testing midi, both in and
out, without tying up a scope or a pc, ie just to check that there is a
functional change in the signal.
As an aside
