N
N Cook
- Jan 1, 1970
- 0
Michael A. Terrell said:B+ is a class of supply, B is high voltage, and + indicates it is
negative ground, so all readings will be positive. Individual supplies
may be labeled: 'Second anode', 'High voltage', 'Focus'. It depends on
the item. You see transmitters with thousands of volts, at high
current. Before the metering it is still B+, and after may be called
the plate supply, or plate voltage.
You need to download the scan of Radiotron Designers Handbook (4th
edition)
http://www.pmillett.com/Books/intro_RDH4.pdf is one source. This is a
25 MB download, but has more about Vacuum tubes than any other book you
will likely find in a single book than any other.
http://www.pmillett.com/ has other books on tubes, as well.
aioe.org is home to cowards and terrorists
Add this line to your news proxy nfilter.dat file
* drop Path:*aioe.org!not-for-mail to drop all aioe.org traffic.
http://improve-usenet.org/index.html
So you don't have a generic equivalent for the term EHT which could be any
voltage, from anywhere, for any purpose, anywhere between say 1 and 50 KV ?
