Fender Twin reverb from 1979
N
N_Cook
Assuming I cannot get 1.5 inch long UNC 8/32 bolts in the UK, other than a
hundred or stupid min order quotes, any suggestions. ? I cannot return this
amp , despite repair, as it is unsafe. The 4 vertically mounted screws that
litterally hold the amp into the cab are stripped to next to useless. Not
captive nuts , nor spire nuts in the chassis part, sort of combination of
both.
Stamped something like
CIP-MUL 832
54 950 / 075
So either woodwork fitting battens along the sides to support amp should
what is left of the screwthreads fail, but amp would be loose then, but not
fall out as such. Or fit metric captive nuts into the chassis and replace
the screws with metric. Or any other work-around suggestions.
I'm not interested in purists opinions , decrying non-originality. The
owners mistreat the amp and can keep the originals along with the all too
tempting-to-turn rear voltage selector knob . Fine for USA but out and out
safety hazzard in the UK, especially the way this lot abuse their kit.
Removed and plated off over the spindle and knob fitted internally inside
the amp for any later purists. Not enough thread for a spindle lock.
jerryg50
Apr 18, 2010
57
Whey don't you go and see someone locally who does mechanical work?
Also, if you contact the manufacture I am sure they can supply you with what you need.
You must have some big hardware centers near to your city. If you are inovative and don't want assistance from the manufacture you should be able to work something out.
Jerry G.
Phil Allison
"Nutcase _Kook"
this
that
both.
** A 1979 Fender Twin Reverb is the 135 watt model - with ultra-linear
output stage.
The chassis looks like this:
http://www.tru-solutions.jp/Fender_Twin_Reverb_79_JBL_04.jpg
The black steel U-clips take the thread of the four top bolts - they will
also accept ordinary self tapping screws of the right size.
The three holes in the back edge take self tapping screws driven into the
top of the cabinet and will hold the chassis solidly in place *on their
own*.
The
** The red voltage selector knob merely has to be removed to eliminate the
hazard.
...... Phil
jerryg50
Apr 18, 2010
57
"Nutcase _Kook"
> this
> that
> both.
output stage.
own*.
> The
hazard.
...... Phil
I would take your amp to someone who can do basic machine metal hardware work. There are many people in this type of business. They can make new fittings with new threads. A good mechanical engineering tech can custom make you bolt fittings and etc.
I myself worked in a service place that used to do this type of custom work when there was no other alternative. ;)
Jerry G.
N
N_Cook
Meat Plow said:
Remove the captive nuts and replace with the correct length bolts with
counter-sunk heads and non-captive nuts with a flat washer against the
chassis and star washer on top. This has been done many times
especially when captive nuts are lost as they can pop out easily.
Are you a magician. ? The point of captive nuts is no spanner required to
turn the nut as there is no access plus easier manufacturing of the chassis.
I've found some 4mm captive/caged nuts, that with a bit of coaxing will go
into the existing holes in the chassis without enlarging. And 4mm stainless
steel bolts of the right length. The 3 screws at the rear are into cabinet
wood that may as well be made of paper as far as resisting the weight of 2
large transformers + + in a cantilever action.
N
N_Cook
BTW that decayed horse manure or goaty smell inside the amp . What is it
they add to winding wire insulation in the US that biologically breaks down
with UK damp air or whatever is the cause. No particularly unpleasant but
I'd rather the workshop smelled of bakelite or shellac say, rather than a
farmyard
Phil Allison
"Nutcase Kook"
The 3 screws at the rear are into cabinet wood that may
of 2 large transformers + + in a cantilever action.
** There is ZERO " cantilever action" involved - since the front of
the chassis is firmly trapped between the top and sides of the cabinet and
the speaker baffle.
Dickhead.
.... Phil
N
N_Cook
Meat Plow said:
I've held regular nuts in my fingertips while threading them onto
screws in Fender combos many, many times. It's not magic but requires
a degree of manual dexterity. Once the nut contacts the star washer it
can be released and the screw tightened from above. If there is enough
room to get your fingertips on the end of the screw there's enough
room to do it this way.
Either you have scissor-hands or these are not original screws. These nuts
are internal of the chassis, not on an external ledge. Overall length 37mm .
Width of cab and spreader plates 25mm , 2mm chassis thickness leaving you
with 37 minus 27 mm to get fingers in and long enough to reach the front
ones. 10mm or 3/8 inch
Phil Allison
output stage.
own*.
You lying fuckwit.
.... Phil
Phil Allison
"Meat Plow"
"Phil Allison"
Well that is certainly different than the Fender chassis I'm referring
to where the bolts go through the chassis and out the bottom.
And those don't look like captive nuts they are clips with a hole in
the middle to hold on a metal screw and not a machine thread.
** The OP stated his bolts were UNC 8-32, 1.5 inches long and there were no
captive nuts - that is exactly what Fender used for many models made in the
late 70s and early 80s.
Was a big improvement over the previous use of very long bolts that wound up
getting bent and were very hard to fit the nuts onto when used near the
power tranny.
..... Phil
N
N_Cook
I'd have more confidence in those 3 wood screws at the rear of the chassis,
into the cab top, if they were longer and set at at opposing angles a la
floor-board nails, for maximum resistance to being pulled out
