Jamie Morken
- Jan 1, 1970
- 0
I am routing a fet's gate drive trace, from a fet driver IC. The
switching frequency is 100kHz and I would like switch times of 20ns.
Is it better to run the gate drive trace "differentially" so that there
is a wire coming back from the fets drain very close to the gate drive
trace, back to the fet driver IC, or is it better to use a ground plane
for the fet's drain (for a low side fet) and run the gate drive signal
on the opposite side of the board above the plane? Which solution has
lower gate drive trace inductance and which would give faster switching
with less ringing?
cheers,
Jamie
with less ringing?
cheers,
Jamie
