- Joined
- Jan 21, 2010
- Messages
- 25,510
It was combined with another thread by Harald Kapp, one of the Super moderators/moderators......
You're right. And maybe we should consider moving it somewhere more appropriate.
The LED should glow (invisibly) as soon as you connect the power.
use a multimeter to measure the voltage across the resistor and also across the LED.
Tell us what they are.
What zener?
Zener diode (protective diode) that protects the IR LED from too much current.
what zener ?? there isnt a zener diode in the circuit, well not one marked as such anyway and if you have one in there then you shouldnt !!
YAY! i got it to work. Thanks Steve. I'm going to try it out with some apps. Btw, how do you make the IR LED go farther in terms of distance so i can cover more ground?
OK, firstly, were you able to modulate the light intensity and prove it by using a phototransistor etc., to receive the signal and convert it back to sound?
The first and simplest is to increase the average current to the LED (possibly using multiple LEDs) and ensure your depth of modulation is high. This will be a lot easier if you drive the LED (s) from a constant current source where the current is set by an incoming voltage (your signal).
However, that's only going to go so far.
To get even more range you need to move to a digital signal where the LED is only tuned on for brief periods (typically at a very high current). This is pretty much how IR remote controls work. The encoded data can be at a higher data rate than your audio signal, does not rely on analog input signals, and can use compression and redundancy to allow errors to be corrected.
No, not yet. I tried to send through the IR LED a Square wave at 108 hz but nothing was happening. So i tried it at 108000 hz (which is like 108 khz right?)
Well, 108Hz is a very low frequency and 108kHz is very high.
Why not start with 1kHz?
What are you doing to receive the signal and amplify it?
I would recommend you use a phototransistor instead of a photodiode (they're easier to work with).
