fibreglass laminate board sources
Geoff Steer
I've been trying to find some fibreglass laminate board (or blank PCB)
that's thicker than the readily available 1.6mm thick
Ideally I'm looking for just the fibreglass laminate but single sided
board is OK as I can strip off the copper.
Thickness required are 2 and 4 mm.
David L. Jones
Does it have to be fibreglass, or will some other material suffice? i.e.
some form of polycarb sheet
What is the purpose?
Try someone like Actronics for FR4:
http://www.acetronics.com.au/
Dave.
Geoff Steer
Dave.
It's to be machined as an insulator covering a small PCB. Phenolic would
probable be OK.
Regards
Geoff
Geoff Steer
Geoff, it will depend on how much of the glass-epoxy board you want to
buy. Bare G10/FR4 is available in sheet form (1220mm x 1020mm) as a
general purpose insulator in thicknesses from 0.2mm up to 50mm.
This company would be worth approaching.
http://www.oba-ic.com.au/oba_Laminates_Sheets.html#eglass
Here is the datasheet on the G10/FR4.
http://www.oba-ic.com.au/pdf/020511_EpoxyGlassG10_0902v3.pdf
Ross,
Thanks for the info.
I'm only after small pieces (25mm x 100mm or so, 5 off) so I'll have to
see if they have any offcuts.
Regards
Geoff
David L. Jones
Geoff said:
Ross,
to see if they have any offcuts.
Regards
Geoff
Why not simply do it as a PCB and order it through your usual PCB maker?
That way it's machined exactly how you want it, no fuss.
PCBcart offer 2, 2.4, and 3.2mm as standard sizes.
Dave.
Ross Herbert
:On Wed, 15 Jul 2009 03:43:13 +0000, Ross Herbert wrote:
:> Geoff, it will depend on how much of the glass-epoxy board you want to
:> buy. Bare G10/FR4 is available in sheet form (1220mm x 1020mm) as a
:> general purpose insulator in thicknesses from 0.2mm up to 50mm.
:> This company would be worth approaching.
:> http://www.oba-ic.com.au/oba_Laminates_Sheets.html#eglass
:> Here is the datasheet on the G10/FR4.
:> http://www.oba-ic.com.au/pdf/020511_EpoxyGlassG10_0902v3.pdf
:Ross,
:Thanks for the info.
:I'm only after small pieces (25mm x 100mm or so, 5 off) so I'll have to
:see if they have any offcuts.
:Regards
:Geoff
They may be able to tell you who buys the stuff from them and you can then
approach these organisations for off-cuts.
