find current source voltage using mesh analysis
tss19
Jun 16, 2013
I need to find the voltage across the current source. I am only allowed to use mesh analysis. What I did is to found all the mesh currents however that does not help on its own.
If you have the mesh currents then you should be able to determine the voltage across the resistors. From that, the voltage across the current source should be trivially obtained I would have thought.
