mikebounds
- Jan 25, 2017
- 8
- Joined
- Jan 25, 2017
- Messages
- 8
I'm looking to build a circuit for a Solar LED light Marker using a very low powered LED like a 0.06W 3528 SMD LED or even lower wattage as the light is to denote where a path is, not to light up a path.
I found a useful circuit at http://www.reuk.co.uk/wordpress/solar/use-solar-panel-as-darkness-detector/, but I wanted to use a 3V 50mAh lithium rechargeable battery and a 52mm x 19mm solette rated at 0.5V and 0.14 watt.
I have measured output from solettte on a multi meter and in dark conditions it produces 0.003mA at 9mV which is about the level or lower that I want the LED to come on.
How would I amend the circuit for this, in particular the transistor, as I cannot find a transistor that will switch at such low amps (3nA !) and voltage?
Mike
Mike
