Finding phase angle of transfer function for hi and lo pass filters
Jodles
Nov 19, 2010
13
Hi!
I'm trying to derive the argument of H(jw) for hi and lo pass filters.
So far I've gotten the following:
for low pass:
From the voltage dividor I've gotten: H(jw) = 1/ (1 + j(w/w_c)) (w_c = ang. cutoff freq.)
Then I found the angle by converting it to polar form and I get:
arg H(jw) = arctan (w / w_c)
But to my knowledge, it should be H(jw) = - arctan(w/w_c). Where is this minus coming from?
Same thing with hi pass. Following the same procedure as above, starting with H(jw) = 1 / (1-j( w_c / w ) ), I get:
arg H(jw) = arctan (w_c / w)
I also know I "should" be getting H(jw) 90 - arctan (w_c / w).
I can see this by recognizing how the filters work and how the output voltage lags the input voltage. But I don't see how this happens mathematically?
Any help would be much appreciated!
barathbushan
Sep 26, 2009
223
step 1 ) factorise H(jw) = 1/ (1 + j(w/w_c))
i mean multiply both numerator and denominator by 1 - j(w/w_c) , and then
separate real and imaginary terms
step 2) angle = tan (imaginary/real)
step 3) its your homework
Jodles
Nov 19, 2010
13
Thanks! I tried that earlier but ended up with a huge equation. Will try again!:)
Jodles
Nov 19, 2010
13
Ok, I've now gotten the right answer for the lo pass. But for the hi pass filter, I get:
1 / (1-j w_c/w) = (1+jw_c/w) / (1+w_c^2 /w^2), then separating these and taking the arctan of b/a, I get w_c /w as before. Where do I find the 90 - arctan w_c/w?
