Derek Broughton said:
Absolutely. In any case, I don't much care if the story was true (I
didn't
say it was - just that that was what the _utilities_ had claimed), the
fact
that it is being propagated _by_ the utilities takes it out of the realm
of
urban myth. It might simply be propaganda, but it isn't myth.
In any case despite Flare's stupid insistence that anyone who does suffer
from such backfeed deserves what they get, it's clearly _possible_ and
that's why we have safety regulations.
Our utility, NationalGrid (formerly NiagaraMohawk) has a 'little' trailer of
a mockup of a couple of poles and typical service entrance they use for
training various volunteer fire departments, rescue squads and such. They
come to your parking lot, set things up, have a *real* line crew go through
all the safety precautions and stuff.
Then they show the fireman how a fireman's 'rubber' boot is absolutely
*useless* for electrical protection by drawing a 4160 arc thru it to ground.
They put a live line across a 'car' (and old klunker they bring with them)
and show the arc when they attempt to ground the frame so rescue squads can
understand the risks of touching a car trapped by a live line.
And one little part of the demonstration is a little 3000 watt homelite
portable generator fed into the 'residential service' panel. They
disconnect the normal supply, and with just this little portable unit
running, supplying a couple of light-bulbs in the 'service panel', and
backfeeding to the 'pole pig' and such. Then they proceed to use a hot
stick to try and connect a ground clamp on the 4160 line. As you might
expect, the 'arc and sparks' are impressive (when seen from a distance).
The lineman was able to draw a couple of feet long arc and sustain it for
almost 30 seconds while the generator just buzzed along.
Depending where a break is, and the surrounding T&D lines, a 'little
portable generator' can be quite a hazard. And all it takes is one screw up
and the homeowner will find themselves paying lawyers for years. That's why
the NEC and CEC require the types of disconnects they do.
daestrom
