Flexible Instruction Set Encoding.
Skybuck Flying
Also I am not sure what you mean with code size ?
If you mean "operand size".
Then AMD probably did not include something like that because the manual
clearly says the rex prefix must be used to specify a 64 bit operand size !
Except for instructions that modify the RSP.
No idea yet what RSP is... 64 bit stack pointer ?
Bye,
Skybuck.
Skybuck Flying
Quadibloc said:
Ah, but there are still mode bits so that what the instruction does
*without* the prefix may be 16, 32, or 64 bits depending on the mode.
John Savard
Where in the manuals can I read about this ?
(So far I am reading the intel manuals ;))
Maybe I should give the AMD manuals a try ! ;)
Bye,
Skybuck.
Skybuck Flying
John Larkin said:
The LINC-8 had a mode bit, and would execute PDP-8 or LINC programs.
In addition to a totally different instruction set, the PDP-8 was a
2's complement machine, and LINC was sign-magnitude.
The S/360 could run 1401 opcodes! VAX had a PDP-11 mode.
As noted elsewhere, a Pentium can run in 16 or 32-bit mode. The
preamble byte flips the next instruction into the opposite of the
current mode.
This is called the instruction prefix which is added before each
instruction.
This means either two things:
1. Write two code paths. <- Undesirable.
2. Modify each instruction at runtime <- Insanely slow.
And you probably miss-interpreted that person too, this person probably was
not even talking about the instruction prefix ! But about something else !
Skybuck keeps inventing things that were already invented decades ago,
probably because he does no reading, no research.
This remains to be seen.
Your lack of accuracy will prevent you from ever turning up any prove what
so ever that my invention was already invented ;)
Bye,
Skybuck.
David Brown
Skybuck said:
The insult is also like a joke.
It takes a long time for you for this knowledge to penetrate you brain !
LOL.
You really do have a problem communicating with people, don't you?
You've managed to insult and alienate everyone who has tried to give you
help in developing your programming skills and ideas. These are people
with far more experience than you of *real* programming, not just
obsessing about meaningless details. They have given polite and
thoughtful answers, but you respond with all the social skills of a
badly raised ten year old. Tagging an "LOL" on afterwards does not make
it any better - it just makes you look even more childish. Come back to
us once your voice breaks.
Michael A. Terrell
krw said:
Mary Ann?
Mary Ann had brains, too. Think about it. Who only had two neurons
left?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
MooseFET
Using a switch per operation is still too much overhead for addition and
subtraction.
I tested it yesterday. Overhead is near 33%.
That depends a lot on the compiler, the processor and the routine
around it. The simpler the code, the more the overhead will show. If
you look at a longish routine, you will see that the overhead is quite
small compared to the other code.
Call overhead method can be even worse.
The call method involves a "call" and a "return". The jump method
needs two jumps. A very smart compiler can pick the faster way.
MooseFET
I am pretty sure virtual methods are too slow, even if it's a single switch.
Even if the virtual methods add only one instruction it's still too much
overhead !
The only thing that remains interesting is the mode switch.
LOL.
I had typed in some interesting stuff pointing out some cute tricks in
the design of CPUs and software that you may have found useful. I
then saw the insult. I don't see any point in bothering.
MooseFET
386 assembler can do 16 or 32 bits like that, and now 64 bits are
included with x86-64.
But not C code, because the C language requires you to specify types;
it does not assume that it is going to be compiled for a machine with
mode bits.
Some languages let you specify "generic" routines, but that just means
the compiler generates a version of the routine for every type
required.
With a bit of trickery, you can do the same with C using include
files. You can change the "#define"ed constants and include the same
code section over and over again.
This lets you have the same code file create the different sized and
swapped endian versions of routines.
Skybuck Flying
I need some clearifications concerning this L thing you mentioned:
4.2.1 Code Segment Descriptor in 64-bit Mode
Code segments continue to exist in 64-bit mode even though, for address
calculations, the
segment base is treated as zero. Some code-segment (CS) descriptor content
(the base address
and limit fields) is ignored; the remaining fields function normally (except
for the readable bit
in the type field).
Code segment descriptors and selectors are needed in IA-32e mode to
establish the processor's
operating mode and execution privilege-level. The usage is as follows:
.. IA-32e mode uses a previously unused bit in the CS descriptor. Bit 53 is
defined as the
64-bit (L) flag and is used to select between 64-bit mode and compatibility
mode when
IA-32e mode is active (IA32_EFER.LMA = 1). See Figure 4-2.
- If CS.L = 0 and IA-32e mode is active, the processor is running in
compatibility mode.
In this case, CS.D selects the default size for data and addresses. If CS.D
= 0, the
default data and address size is 16 bits. If CS.D = 1, the default data and
address size is
32 bits.
- If CS.L = 1 and IA-32e mode is active, the only valid setting is CS.D = 0.
This setting
indicates a default operand size of 32 bits and a default address size of 64
bits. The
CS.L = 1 and CS.D = 1 bit combination is reserved for future use and a #GP
fault will
be generated on an attempt to use a code segment with these bits set in
IA-32e mode.
.. In IA-32e mode, the CS descriptor's DPL is used for execution privilege
checks (as in
legacy 32-bit mode).
This setting
bits. The
As you can see from the text above, the default operand size remains 32
bits.
There is no easy way to convert exisiting code from 32 operand size to 64
operand size or vice versa.
Maybe they could use:
To implement it.
Possibly and interesting discovery/idea that's why I renamed the topic so
this text is easy findable and people hopefully notice it in this messy
thread ! ;) :)
Bye,
Skybuck.
Skybuck Flying
EXACTLY.
The whole idea is too minimize all other overhead.
To get a very good idea how much this single switch adds in overhead.
If this single switch is done everytime a calculations must be performed
then ofcourse it's really important to test how much this single switch adds
in overhead !
Let's face it, this test is a optimal test there is only one branch maybe
two that get called, so branch prediction should be 100% optimal. The branch
taken is always the same.
So even during this optimal condition test the OVERHEAD IS HUGE.
That means during a real program the overhead might even BE WORSE.
Not that much difference between a jump and call.
Bye,
Skybuck.
Skybuck Flying
Blablablablablablablabla LOL.
Others have insulted me as well, and they not joking it seems.
Some simply assume there 16/32 bit knowledge simply translates to the 64 bit
case.
I have discovered this is not the case.
Not all features are present in the 64 bit design of AMD.
Especially the segment descriptor mode switch for default operand size 64
bit is missing !
AMD could implement it by using the reserved bits (CS.L=1 and CS.D=1) for
future use, me thinks !
And there ya have it folks !
Skybuck telling you people how to extended your limited processors !
A nice symbioses between old farts and young talent like me ! LOL.
Bye,
Skybuck.
Skybuck Flying
Good because you are the one with the thick skull if I am not mistaken ! ;)
Bye,
Skybuck >D
Rudy Velthuis
Usually after you treated them with insults, insinuations and stupid
remarks. It was you who most of the time behaved like an idiotic badly
raised teenager.
Your "blablabla LOL" is another example. You obviously have never
learned to get around with people. People are much more likely to
actually help you (and you need a lot of help, even if you think you
know everything already - your utterances show you are extremely
inexperienced) if you treat them respectfully. They are much more
likely to treat you respectfully as well.
Jamie
SpooK said:
Arrogance and ignorance usually go hand in hand :)
ah, I work with some one that fits that description exactly! :)
How ever, this person I speak of contributes so little to the
group I work in, I didn't realize he's been on vacation for
the last 2 weeks! :)
Nice that some can see the fog before they drive into it.
SpooK
Spot on for Rudy and Jamie.
It almost seems like the ignorant are either too lazy or too scared to
accept and assimilate knowledge... that would force them to do
something outrageous like... LEARN and ADAPT *shudders*
Only if SkyBuck would take the advice everyone gave him... he might
have a chance at remedying his ignorance, impatience and laziness.
However, if SkyBuck insists on acting like a script-kiddie, we'll
continue to treat him like one :)
On an honest side-note, people like SkyBuck scare me... they're the
types who try to conform hardware to meet software constraints... the
opposite of a productive endeavor indeed :S
Jamie
:) well put!
Skybuck Flying
Typical, now you people must admit defeat you get personal and start trash
talking LOL.
That's the sound of victory ! =D
HAHAHAHAHAHAHA
Bye,
Skybuck.
SpooK
talking LOL.
HAHAHAHAHAHAHA
Bye,
Skybuck.
We have enough people around here who blow smoke and declare some sort
of "victory" with blatant disregard to reality and fact. Pity that you
should start that at such a (self declared) young age. Soon enough,
you will find yourself turning in to a Straw Man incarnate.
Good luck with how far your myopic point of view gets you in this
world :)
