Flux Remover (5252) precautions?
Myauk
Dear All,
We use Flux Remover 5252 to clean our PCBAs after manual soldering.
As I am a new guy in this assembly process, I don't know whether there
is any critical component sensitive to this solvent.
We have DSPIC, a few FETs, Voltage Regulator ICs and SMT passive
components on the PCBA.
Any suggestion?
Regards
Phil Allison
"Myauk"
** Email the makers for info that.
Their web site doe not say what the solvent consists of nor is there any
MSDS on the site.
Very bad.
At a guess, it is basically IPA, which is pretty harmless to components.
...... Phil
Myauk
This shows the contents:
http://nteinc.com/MSDS/kester/MSDS 5252 US (11Sep03).pdf
The acetone could lunch some plastics and maybe film capacitors. The
parts you mention, assuming surface-moung ceramic resistors and caps,
should be OK.
It does look a little harsh for general-purpose electronics cleaning.
How do you apply it?
John
Dear John,
Thanks for the info.
We soaked a piece cleaning cloth with the solvent and then cleaned the
soldered joints.
Will there be any problem?
Should we use a better type of solvent?
Regards
Aung
K
krw
"Myauk"
MSDS on the site.
Very bad.
Unless they drink too much.
N
Nico Coesel
Myauk said:
Dear John,
soldered joints.
Not if you are using a fume hood and proper gloves as personal
protection. IPA (non drinkable clean alcohol) is a safer choice, but
works slower.
K
K Ludger
John Larkin said:
The main ingredient in 5252 is ipa, or its near cousin...
http://en.wikipedia.org/wiki/Propanol
Pure ipa tends to leave white crud when used to remove flux, hence the
additives.
John
I thought the white crud left behind was the "acid salts" from the flux and
that the alcohol as a non-polar solvent dissolved the rosin but not the
salts. I thought a polar solvent (like water) was needed to get rid of the
salts - or is acetone or mentha-1,8-diene polar?
I always liked TCE ;-)
                                        ...Jim Thompson
| James E.Thompson, P.E.                           |    mens     |
| Analog Innovations, Inc.                         |     et      |
| Analog/Mixed-Signal ASIC's and Discrete Systems  |    manus    |
| Phoenix, Arizona  85048    Skype: Contacts Only  |             |
| Voice:(480)460-2350  Fax: Available upon request |  Brass Rat  |
| E-mail Icon athttp://www.analog-innovations.com|    1962     |
 I love to cook with wine     Sometimes I even put it in the food- Hide quoted text -
- Show quoted text -
That sh*t worked good too. A little bottle on your bench. Alcohol is
so pathetic.
K
krw
That sounds strange, doesn't it?
Back in the days when Freon was declared good... now Freon is declared
bad ;-)
DDT was once declared good too, before Africans were declared bad.
