FM Radio
audioguru2
Apr 6, 2004
12,026
mr_popo said:
Hi Mr. Popo,
Welcome to our forum. ;D
I can't find the parts BB329 and BB105. Any suggestion for a replacement for these parts?
Like the project says, steal a varicap diode from an old TV tuner.
Do you know where to get an old TDA7000 radio IC? It also hasn't been made for years.
mr_popo
Sep 14, 2005
3
thanks a lot. they still sell these ic's here in the philippines. good thing they have it. but in case these aren't available here, what can i use as a substitute?
audioguru2
Apr 6, 2004
12,026
The new Philips FM radio ICs had tiny surface-mount packages and didn't have a tuning control. They scanned and stopped at the next station. They don't make the scanning ones any more, I guess because they were copied in China. They sell the new TDA7010 in a surface-mount package and it seems to be the same as the TDA7000.
My wifey got a couple of the tiny scanning radios for free by signing-up for newspaper delivery. They sound terrible and the signal must be very strong or the sound fades and distorts. I thought the bad sound was from the cheap earphones, but they sound excellent on my Sony Walkman and CD player.
I saw the radios at The Dollar Store selling for $2.00CAN complete with the earphones and two AAA battery cells. Oh yeah, the radios also have a cheap flashlight built-in.
mr_popo
Sep 14, 2005
3
i have a MV104 and MV1650 both varactor diodes , can i use these for replacement for BB329?
audioguru2
Apr 6, 2004
12,026
Hi Mr. Popo,
They are completely different.
The BB329 has a wide tuning capacitance range of 12, the others only a little more than 2.
I copied and pasted their datasheets from www.datasheetarchive.com .
spynettz
Jan 18, 2006
hello.. we tried doing the same project, there are hummings but no radio stations. we were not able to fine polyester.. we used mylar instead...,, is there any way it will work?
pls e-mail me at: [email protected] for any suggestions..\
thanks very much!!
audioguru2
Apr 6, 2004
12,026
Your capacitors are fine. The little ceramic ones must be ceramic.
Humming indicates mains interference pickup. Maybe the wires in your circuit are too long. Radio circuits won't work on a breadboard because the long wires and rows of connections have too much stray capacidance and inductance. Therefore a pcb must be used with very short printed wiring.
The coil must be exactly like it says (if you can understand the poor translation). The 5+5 turns of enamel-insulated wire in the coil must be touching I think. Spread the turns a little and tune the pot and maybe it will work.
Use a pot for tuning it before trying to tune it from your computer.
mvs sarma
Feb 12, 2006
234
hai all
plsee carefully the FM radio schemtic of the project and you will appeciate that
THE VARYICAP IS SHOWN CONNECTED WRONGLY-- IT SHOULD BE IN THE REVERSE DIRCTION TO THE BATTERY POLARITY, ON THEN, THE DIODE WOKS AS A VARYCAP
PL TRY OUT YOU ARE SURE TO START RECEIVING STATIONS
anxious to get feedback
sarma
MP1
Dec 7, 2003
3,399
sarma,
variable caps are not directional like an electrolytic.It does not matter which direction you connect.
However, I do not see one in the project. Are you discussing the project in our project section here?:
http://www.electronics-lab.com/projects/rf/020/index.html
MP
audioguru2
Apr 6, 2004
12,026
Sarma is talking about the BB329 varicap tuning diode that is backwards in our project. It is supposed to be reverse-biased but is shown connected with forward bias.
Nice going, Sarma, you have good eyes. ;D
MP1
Dec 7, 2003
3,399
Good. I have notified Kyriakos to correct his schematic and re-post.
Sarma, thanks for the correction. Since I was not following this thread, I read your post as variable cap and not varicap.
If this schematic does not get corrected in the next month or so, please remind me and we will correct it without the original author's intervention.
MP
AN920
May 15, 2005
359
The cathode side of D1 is connected to +5V through L2 as it should be or is this already modified?
N
nanop
Is it true that u can descramble cable using a variable cap?  ;D
MP1
Dec 7, 2003
3,399
I haven't looked at the schematic for the problem yet. No it has not been changed from the original. I have only asked the original author to get involved.
MP
AN920
May 15, 2005
359
I see the drawing has been modified now. The anode is connected to +5V through the inductor. This is wrong! The diode will now be conducting when the pot is set low enough or less than 4.5V on the slider. It will not function as a varicap anymore. The original diaram was correct.
audioguru2
Apr 6, 2004
12,026
I think the varicap diode was backwards, then it got reversed recently, then it got reversed again recently. It is odd that the schematic doesn't say anything about the "correction".
audioguru2
Apr 6, 2004
12,026
My cable-TV company changed all pay-per-view to the digital channels years ago.
In 1980 I modified my TV to unscramble the scrambled analog signals. My circuit was a lot more than just a variable capacitor since the sync was suppressed at certain times and needed to be detected, made then re-inserted when needed. The picture also went negative at times, which needed to be detected, made in reverse then re-inserted. Making the picture reversed wasn't easy because the colour burst must be left the same as original, or the colours would be reversed.
MP1
Dec 7, 2003
3,399
The diode was not originally backwards. I should have looked closer after you the two of you told me it was wrong. Datasheet shows that it was in the correct placement.
This is why I strongly press on members that we do not make changes unless you are actively bench testing a project. This is the mess that results from it.
I think the original author might have re-submitted the schematic since I inquired about it to him.
MP
AVRFreakMan1
Aug 1, 2003
52
I haven't done any changes in this circuit.
This is my reply in MP's email notification that I got yesterday:
Hello Mike.
The circuit is correct. I had to sit back and think of the theory behide the
varicaps for a while and check the real PCB. The result is that the circuit
is correct. Every varicap, like zeners, has to be biased in reverse order,
otherwise it acts as ordinary diodes. If you see, the cathode is DC
connected to the +5V line, via the coil, and the anode is allways connected
to a lower voltage, via the potensiometer.
The PCB is verifying this. The black line in diode's body goes to +5V. I
made it severals years ago and was hard to find it in the pile, but still
works! Here is a foto that I took yesterday with my mobile phone camera,
while I was listening some random radio station.
I used the BB329 varicap in this prototype and works very well.
However, I should say a few more words that may not be obvious.
1) The operation range of the varicap in this circuit is 0..5V. The BB329 works up to 32V but here is used up to 5V. This results in about 40 to 15pF.(The datasheet is wrong when it says VR=3V -> ~3pF. It should say VR=30V -> ~3pF. Check the "Capacitance versus reverse Voltage daigram".) Use a similar varicap.
2) If you decide to use the LPT option, cut the line in point "A", delete the potensiometer and connect the "B" point, to wiper's line. If you leave the pot in, you may use it for manual micro-tuning but it will introduce some unwanted voltage drop of the R2-R LADDER circuit.
3) In my prototype I used the LPT option, without any potensiometer.
Furthermore, I added an op amp connected as a buffer x1 from "B" to "A", just to be sure that the R2-R LADDER circuit will work with my LPT port. However if the pot is deleted, the buffer is not necessary.
P.S.
Dont's ask me for the PCB layout. I tranfered the circuit by hand directly into the PCB. One time job.
KyriakosView attachment 39683
