Fm transmitter
karthikeid
Dec 7, 2008
94
hi
i need a fm transmitter circuit that works properly, very urgent pls help me. ::)
Hero999
Oct 28, 2007
2,433
http://www.silicontronics.com/index.php?action=ezportal;sa=page;p=15
karthikeid
Dec 7, 2008
94
can u tell me wheather this circuit works out well
http://www.aaroncake.net/circuits/fmtrans.asp
Hero999
Oct 28, 2007
2,433
I should can this response.
That circuit has, no RF buffer amplifier, so the frequency will drift if objects are placed near the antenna, no voltage regulator, so the frequency will change as the battery runs down and no pre-emphasis so it will sound like an AM radio.
karthikeid
Dec 7, 2008
94
hi
i have made this circuit
http://w1.859.telia.com/~u85920178/tx/bug5.htm
at one frequency it is working fine for a long distance but when i speak there is bzz noise nd not able to hear clearly, can u help me to overcome this problem ???
in this circuit i have used 10pf instead of 12pf....
Hero999
Oct 28, 2007
2,433
Why did you ask for a circuit that works, if you were only going to build a different one that doesn't work?
I could be many things.
Are you powering it from a mains adaptor? The internal capacitor might not be large enough so add a 1000
audioguru2
Apr 6, 2004
12,026
The electret mic must be connected with the correct polarity. Its metal case has the wire that should be connected to the circuit's ground.
The mic must be connected with very short wires or with a shielded audio cable.
You must not touch any part of the circuit when it is transmitting to avoid hum pickup from your hands.
karthikeid
Dec 7, 2008
94
hi
in this circuit
just change 547 which is parallel to 2.7pf, into BF494 then it is working fine
karthikeid
Dec 7, 2008
94
hi
http://rapidshare.com/files/276652026/fm_transmitter.pdf.html
check this circuit need some help building this one... ;D
audioguru2
Apr 6, 2004
12,026
hi
Please attach your schematic here instead of over at RapidShare.
The very old circuit will sound bad and have its frequency change when its supply voltage changes.
I don't know where you will find a clip-on heatsink for the output transistor.
karthikeid
Dec 7, 2008
94
hi
can u provide me some other circuit that will have a good range...
Hero999
Oct 28, 2007
2,433
I've already done that, read my first reply to this thread.
Hero999
Oct 28, 2007
2,433
500m through what? Free space, a forest or town?
What receiver are you using? A cheap Chinese FM radio won't be able to pick it up from as far away as well as a state of the art car radio.
What aerial are you useing? A high gain yagi array will transmit/receive the signal from a long away but will be more directional, a simple monopole will not transmit/recieve the very var but will pickup/send the signal in all directions.
audioguru2
Apr 6, 2004
12,026
My FM transmtter has a range of more than 2km to my extremely sensitive home stereo and car radio.
Its range is 300m to my cheap Sony Walkman radio.
Its range is 100m to a cheap clock radio.
Its range is across the street to a cheap scanning radio from The Dollar Store.
karthikeid
Dec 7, 2008
94
hi
some of the components are not presently available to me to build that circuit...
but i have attached one more file can u provide me some suggestions on it...
i am not able to attach the file here saying the dir is not writable here...
so i have uploaded in rapidshare sorry for the inconvince.
http://rapidshare.com/files/277282868/transmisso__fm.gif.html
in this circuit 0.3uH is given how to wind the coil ???
Hero999
Oct 28, 2007
2,433
Which components can't you get hold of?
It's possible to substitute some of the components.
Rapidshare has limited downloads per day unless you pay, for images use www.tinypic.com which has limitless sownloads.
