Fm transmitter
karthikeid
Dec 7, 2008
94
hi
can u modify this circuit with an electret mic and all the correction to work well because
i am looking for a smaller size transmitter  ???
the previous circuit u gave works fine too...but little big one :(
audioguru2
Apr 6, 2004
12,026
Simple circuits never work well because important things are missing.
This one also needs to have a regulated power supply because it is tuned by voltage. Without a regulated voltage the frequency will change as the battery runs down.
With a regulated power supply and a mic preamp with pre-emphasis then the circuit will not be small.
audioguru2
Apr 6, 2004
12,026
hi
can u post me anyone circuit here pls ???
Electret microphone preamp circuits are on my hard drive but you can find them on Google.
Pre-emphasis circuits the same.
Voltage regulator circuits the same.
Do it.
Hero999
Oct 28, 2007
2,433
Why don't you just use the circuit from the datasheet?
Always read the datasheet very carefully before implementing the circuit.
As you've realised, you need a pre-amplifier so why not just look up non-inverting amplifier on Wikipedia and change the resistor values to get the required gain?
To figure out the gain look at the datasheets for the transmitter IC and the electret mic.
karthikeid
Dec 7, 2008
94
thanks for the information provided i am update the complete circuit once i have build it...
karthikeid
Dec 7, 2008
94
what will be range of transmission...will this be a better transmitter ???
audioguru2
Apr 6, 2004
12,026
You didn't post a better transmitter.
The MAX2606 has a low supply voltage and a low supply current so its output power is low. Its range might be a few hundred metres to a very sensitive home stereo tuner or car radio with nothing in between or across the street to a cheap clock radio.
audioguru2
Apr 6, 2004
12,026
how this circuit works can u explain audioguru  ???
will this be efficient??
It is a garbage circuit that causes interference on many frequencies. It will barely work as an FM transmitter because its 9th harmonic (96.3MHz) is at a very low level.
Its fundamental oscillator is at the 10.7MHz of the crystal filter. It is a squarish-wave with many harmonics and the 9th harmonic (96.3MHz) is in the FM broadcast band.
karthikeid
Dec 7, 2008
94
i am really confused what to do, i need a stable fm transmitter circuit and it must be smaller in size.... someone pls help ???
audioguru2
Apr 6, 2004
12,026
The MAX2606 FM transmitter IC comes in a small surface-mount package. It operates at a low current from a low supply voltage so its range is only about 20m.
Here is a project: http://electronicsprojects.mediadir.in/?p=1879
It is missing pre-emphasis equalization so it will sound muffled (no treble frequencies) when heard on an FM radio. View attachment 40825
Hero999
Oct 28, 2007
2,433
It depends on what you're doing.
How good does the transmitter need to be?
Is it just a simple listening device which only needs to be telephone quality or is for a singer's mic. which needs to sound crystal clear?
If all you want to do is build a simply listening device a simple two transistor FM transmitter will do. It doesn't need pre-emphasis or anything fancy.
If it's a singer's mic. then you need a high quality amplifier with pre-emphasis.
Either way the circuit originally posted is a bad idea because it will generate lots of interference on other radio bands.
