Frequency Divide by 2.5?
Jackson Harvey
I ran into a divide by 1.5 circuit that uses a positive-edge triggered
flip-flop and a negative-edge triggered flip-flop. I like the concept,
but I need to divide by 2.5. Has anyone seen such a circuit, or have
any idea how to go about designing it?
Divide by 1.5 is at:
http://www.designnotes.com/CIRCUITS/divide3_2.htm
Jackson Harvey
mike
Jackson Harvey
divide by 5 then use an edge detector to double it.
mike
Bunch of stuff For Sale and Wanted at the link below.
laptops and parts Test Equipment
4in/400Wout ham linear amp.
Honda CB-125S
400cc Dirt Bike 2003 miles $550
Color LCD overhead projector
Tek 2465 $800, ham radio, 30pS pulser
Tektronix Concept Books, spot welding head...
http://www.geocities.com/SiliconValley/Monitor/4710/
red rover
Or if you like, use a x5 PLL and use a flip-flop to
halve it.
Steve
Jim Thompson
Jackson Harvey
See "DivideBy2p5.pdf" on the S.E.D/Schematics page of my website.
I am in no way a digital designer... there may be a more compact
realization. Probably someone here who knows VHDL can concoct such a
version.
...Jim Thompson
Robert Baer
halve it.
Steve
If one multiplies by five, then divides by two, that is a
multiplication of 2.5 - not a divide by 2.5 ....
Sir Charles W. Shults III
You need to divide by five and multiply by two. Simplest method that will
also produce a symmetrical output.
Cheers!
Chip Shults
My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
W
Winfield Hill
Jim Thompson wrote...
a version.
I designed a divide-by-2.5 that uses three flip flops (instead of
four like Jim's). If one wants a symmetrical output it uses a four
quad NOR-gates. It doesn't require two types of gates (e.g. like
Jim's Exclusive-OR and AND gates). Although it uses three logic
packages, it has one left-over flip flop. If an asymmetric output
is acceptable, two gates also remain unused. Like Jim, I suspect
a more simple implementation may be possible.
- Win
whill_at_picovolt-dot-com
F
Fred Bloggs
Jackson Harvey
There is a simple way to divide by N/2 for any odd N- all these circuits
stink from a phase noise perspective. You're not a hardware person and
that shows- stick with your programming and post your trivia to basics
from now on- you're deluded to think your joke of a question flies here.
Jim Thompson
- Win
Can we see your schematic?
...Jim Thompson
Jim Thompson
Whatsa matta Fred, spend all Friday night drinking ?:) You sure are
a cranky old bastard!
...Jim Thompson
Jim Thompson
- Win
Eh? It just struck me what you said, "If one wants a symmetrical
output it uses a four quad NOR-gates".
SYMMETRICAL? How are you doing that with DIV 2.5 ?? That would take
a transition at quarter-cycle of the input clock.
...Jim Thompson
Joe Legris
Hey Bloggs, you've been quite civil for some time, but now you're
changing into Mr. Hyde again. What's happening?
petrus bitbyter
version.
...Jim Thompson
Look at:
http://www.xilinx.com/xcell/xl33/xl33_30.pdf
I can imagine other designs as well. For example you can multiply the clock
by two, using a quad exclusive or (7486) to produce a short pulse on every
clock edge and then divide this by five using a 7490.
petrus
Jim Thompson
Look at:
petrus
[snip]
Clock ×2 is what I did using the '74 plus an XOR.
...Jim Thompson
John Popelish
The concept for integer dividers is to count only the transitions that
go in one direction. The concept for half integer dividers is to
count all the transitions. So a divide by 2.5 is a divide by 5
counter that counts all transitions. However, if the original
waveform is not symmetrical, then there will be a bit of asymmetry in
the output wave, if that matters.
gwhite
It isn't "noise."
gwhite
Jim said:
Fred is referring to the noise problems when used in a PLL.
Please elaborate. Like Popelish wrote "However, if the
original waveform is not symmetrical, then there will be
a bit of asymmetry in the output wave, if that matters."
That would create a deterministic spurious output if applied directly to a PD
(like primitive fractional PLL's that don't "randomly" insert the extra
clocks). But deterministic is by definition not random. Noise is by definition
random. What inherent feature of these circuits creates a "high amount" of
randomness? Why would anyone apply the output of this circuit directly to a PD?
Jim Thompson
I didn't say Fred was right ;-)
If you feed the result of the DIV2p5 into a single edge sensitive PD
there would be no problem.
...Jim Thompson
Jackson Harvey
I am not sure if this was directed at me, since the reply does not seem
to fit my question. Just in case, though: I am a hardware designer, but
not a digital designer. You seem to have made some assumptions that are
not warranted. I do not care about duty cycle, and I do not care about
phase noise. What I actually need is a divide by 5 with approximately
50% duty cycle, and I know that the input duty cycle is nearly 50%. I
will follow it up with a divide by 2 to give me approximately 50% duty
cycle, and approximately is good enough for my application.
BTW, I have found many ways to solve the problem, but am working on
generating the minimum hardware solution. Thanks to those who replied
constructively. In case anyone cares, I wrote a program to search the
entire state-transition-table search space, and applied the appropriate
rules to find just those transition tables that lead to a divide by
2.5. It was a fun exercise, but I was left with many answers, so now I
am writing a rule to select the minimum hardware solution.
Jackson Harvey
