Fried pcb for led lamp
Joni
Feb 14, 2023
4
Ceiling lamp pcb got fried after it was installed incorrectly. cables from out end of transformer, were plugged in red to black and black to red.
The lamp has a panel and rgb led strips. It aslo coes with a controler.
I think all I have to do is replace the voltage regulator that got fried.
As seen on the pictures above I removed the capacitor that was covering the burnt component.51B6A5C6-529E-405B-A42A-07CAA4628E7A.jpeg
I also removed the glue
I can Identify the component as a SOT89 78L…. Rest is missing
I think it’s a voltage regulator.
But I have no Idea what voltage I need .
14,312
Possibly a 78L05 (5 V regulator) or 78L03 (3.3 V regulator).
Could be either one, the CPU HT66F018 can operat between 2.2 V and 5.5 V, so that is inconclusive. I'd start with the 3.3 V regulatro and switch to 5 V if 3.3 V doesn't work.
On the other hand, you're lucky if it is really only the voltage regulator, not more.
kellys_eye
Jun 25, 2010
6,512
The diode at the bottom of the last picture is also likely shorted.
Joni
Feb 14, 2023
4
Big thanks for the replies, I’ll try to get a hold of the components. Might take a few months though, since ali express is the only place I was able to find the VRs…
kellys_eye
Jun 25, 2010
6,512
There are many suppliers such as Farnell, RS Components, Mouser etc that stock those items. Most countries have outlets too.
kellys_eye
Jun 25, 2010
6,512
If the pinout matches and the technical spec do as well then float your boat!
Joni
Feb 14, 2023
4
Could you help picking the right diode to replace the one in the picture? I wanna add it to the order incase it’s broken too.
I’ve been trying to figure this stiff out on my own, but I’m not that well versed in this stuff
