John Larkin
- Jan 1, 1970
- 0
That story is some kind of deceitful ruse, no such thing occurred...
Hey, Fred, see pics in abse.
Quoting Johnny Depp in the Willy Wonka movie,
"You are REALLY weird."
John
John said:I submit that if you open up your amp and start tapping parts with a
pencil, the loudest noise you'll hear is the sound of parts being
tapped with a pencil. To solve this particular problem, quit hitting
parts with pencils.
My NMR gradient drivers have a couple of PPM noise, dc to 50 KHz, and
use regular surface-mount parts on FR-4, with lots of noisy fans.
Aside from pure semiconductor and resistor noise, the next biggest
hazard is magnetic loop pickup from fields leaking out of transformers
and fans.
How will a microphonic cap make hissy, buzzy audio?
What if the "tapping" is caused by environmental factors, such as road
vibration, acoustic waves from loudspeakers? Do you just stop the
vehicle by the side of the road? Tell the musicians using your
amplifier at the concert to stop playing so loudly?
Sounds like your NMR machine must be a large heavy device, mounted in a
quiet building somewhere. No worries, then.
Consider that some external source is producing vibrations in the
audible range. Assume the level in the listening room is X dB. How
much additional sound level will be added to the X dB by the gain
associated with a microphonic capacitor and the following
amps/speakers? In other words, the truck itself will make a hell of a
lot more noise than what the truck induces into the cap.
Ever hear a system howl from microphonic caps?
John
Boris Mohar said:I wonder how much distortion do ceramic caps produce by reacting to the
stress produced by their own internal electrical fields that are set up by
the signal itself.
Boris said:I wonder how much distortion do ceramic caps produce by reacting to the
the signal itself.
No decent audio designer wil use ceramic caps in signal paths other than
NPO/COG types.
Medium and Hi-K dielectrics are well known to distort the signal.
Graham
John Larkin said:How can they do that? A coupling cap almost by definition is a low
impedance at signal frequencies, so the voltage drop across it is
small. And if it's inside an overall feedback loop, any nonlinearity
is further reduced.
The only interesting case is a cap that itself defines a low-frequency
rolloff point. If used at high signal levels, that one could in theory
generate harmonics. In practise, I suspect the effects are generally
small.
John said:I had a pll running at 155.52 MHz with a narrowband (2 khz) loop, on a
VME module. Whenever one pulled an SMB test cable out of its
connector, the loop briefly lost lock. After some tapping and bending,
we found it was the expensive Vectron crystal oscillator, not the
caps. We designed some tiny springs to isolate the oscillator can,
made it wobble like one of those gooney-head dolls you see in the
backs of cars.
John said:How can they do that? A coupling cap almost by definition is a low
is further reduced.
small.
John said:Hey, Fred, see pics in abse.
John
Pooh Bear said:Oh, I've measured that. Electrolytics used for coupling that have greater than ~
100 mV A.C. across them generate some weird products. It's not especially
low-level either. The trick is to *never* have that much voltage there. I.e. use
big caps. Using the 'bipolar' versions doesn't help either despite much common
belief to the contrary.
How do you make filters with zero AC voltage across caps?![]()
You're kidding me right ?
Non-linearities in feedback loops can be amplified !
The lengths some people will go to perpetuate their lies...is this some
kind of stock option scam on Vectron?
Holy crap! I had exactly the same problem with a Vectron VS700
155.52MHz VCXO. Only I used an SMA connector for the test points
Stress on the board would pull the oscillator frequency.
My fix was to ignore the problem, as that level of stress only happened
during testing.
Regards,
Allan
martin griffith said:All these "audiophooles" keep going on about OFC etc.
Then I try to imagine (badly) what the hell is going on at the
molecular level inside a decoupling electrolytic. It must surely
outweigh FR4/Teflon problems
All electrical-grade copper is OFC.
Is there any truth behind the argument that OFC doesn't oxidise as much
as normal copper, so it gives less trouble at the speaker and amp
connectors?
nospam said:You don't test audio equipment like this. You need meters for....
Musicality
Etch
Resolution
Glare
Detail
Tightness
Speed
Depth
Size
Location
Pace
Brightness
Balance
Flavour
Bloat
Cleanliness
Extension
Energy
Warmth
Fullness
Weight
Smoothness
Liveliness
Sparkle
Power
Sweetness
Correctness
Naturalness
and that is just for cables.
