Ted Edwards
- Jan 1, 1970
- 0
John said:made it wobble like one of those gooney-head dolls you see in the
backs of cars.
Ummmmmm, I thought those were in the left front seat.
Ted
backs of cars.
John said:You're kidding me, right?
John
Ken said:The bipolar ones are often the worst way to go. Using two polar ones and
applying a large pre-bias works better.
Especially line cords.
Ted
Non-linearity *inside the feedback loop path* is amplified by the feedback factor.
John said:If you mean the actual feedback path, not the forward path, sure. But
the feedback path is almost always passive.
John Larkin said:I don't think it's Vectron especially; all XOs are shock/acceleration
sensitive to various extents. SC-cuts are supposed to be better, at
roughly 3-5x the price.
Sure. But may contain non-linear components such as med or hi-K dielectric caps.
Therefore their use inside the feedback path exageerates their non-linearity and should
be avoided.
I've even experienced non-linear resistors too btw. Just once. A batch of 'bad' 27ks.
Graham
Pooh Bear said:Sure. But may contain non-linear components such as med or hi-K dielectric caps.
be avoided.
Fred Bartoli said:No, it doesn't exaggerate their non-linearity.
Non linerity effects simply can't be reduced there, but no they can't be
amplified.
John said:On 13 Nov 2005 01:44:11 -0800, [email protected] wrote: [snippage]
Geez, don't tell Fred!
OMG, are the audiophools going be pissed at you!
it appeared to be a
steady-state phenomenon. I could stress (i.e. bend) the board a
little, and the frequency would change, and would've stayed changed had
my loop not pulled it back.
^Ken said:My one wasn't sensitive to acceleration;
This sounds like it wasn't actually the crystal that was causing the
shift. Perhaps the capacitors were being stressed and changing values.
[...]Ken said:<[email protected]> wrote:^
Insert the word "very" as marked and I'll believe you but without it, you
would have a very hard time proving it if it ever happened.
Can I use the word 'particularly' instead?
Yes, I had also considered that it might be caused by a 1uF MLCC in the
loop filter. (I don't recall the dielectric material, but it was a
physically large part (1206?).)
Alas, this design has been retired, so I won't have a chance to open
the loop and find the real cause of the problem.
