K
Keith W
- Jan 1, 1970
- 0
I know very little about the technical side of electronics but I can use a
soldering iron. I have two external hard drive cases which use what
"appear" to be identical power supplies. Said power supplies reduce the
current from 240volts AC to the required supply for the hard drive which is
12volts and 5 volts both at 2A which I assume means 2 amp. The sign beside
each is a bar with three dots beneath it which I assume means DC. Although
the power supplies look identical and have the same connectors it appears
that the wiring to the connectors does not match. I inadvertently plugged
the wrong power supply into one of the drive cases and the power supply
ceased working. I have opened the case and found that a fuse, which was
soldered into the circuit board, has blown. I am quite confident that I
could solder a replacement in and I am sure that I can get one in Maplin's
(English version of Radio Shack) but I do not know the technical description
for the part. Can anybody advise what component I should be asking for
please.
please.
