general semi dual mosfets part number in so-8 package
Matthieu Benoit
It seems that General Semiconductors (now Vishay) no longer manufactures
any mosfets.
I am looking for replacing a MOSFET house-numbered by BOSCH / ISKRA
Slovenia "B57916" and with the logo og General Semiconductors.
the package is SO-8 marking after finishes with "NL" which stands for
SO-8 package at GENERAL SEMI.
GND is connected on pin-4
Power os connected on pin-5
pin-1 is connected to a dual-diode BAV70 through some resistors.
any part number (siliconix, etc.. or other that could suit
interest me
Matthieu
F
Franc Zabkar
any mosfets.
interest me
Matthieu
FWIW, General Semi's dual MOSFETs appear to be numbered as GFxxxx.
Unfortunately all the SO-8 packages that I've found (eg GF9926,
GF4953, GF4936, GF2918, GF2524) connect pin5 to drain D2 and pin 4 to
gate G2. A grounded gate wouldn't make sense, would it?
Are any of the pins shorted internally? For example, do pins 5 and 6
both connect to D2 ???
- Franc Zabkar
Matthieu Benoit
- Franc Zabkar
Hi Franc :
There is no pin connected each other
there is something connected one pin 1 : pin 1 through a 100K resistor
is connected to a dual diode BAV70
all the pins have a junction refered to pin 4 (junction of 0.5 volts
with a fluke muli-meter)
seems that vishay do not want to help
Matthieu
Matthieu Benoit
Hi Eveerybody
Seems that this so-8 package integrated circuit from general
semiconductor
may be something else than a dual jfet???
the ic is explosed and the dual diode BAV70 as well.
gnd is on pin-4 and power on pin-5 (power is connected to a LM317T
output through
a resistor) - pin 1 is connected someway to a BAV70 dual diode through
a 100K resistor.
there is no pin connected one another; also when you test with a diode
meter
of a good ic you can see that there is a junction (0.5Volts) between
all the pins
to the ground (pin-4).
any help greatly appreciated.
Regards,
Matthieu
F
Franc Zabkar
Hi Eveerybody
semiconductor
output through
a 100K resistor.
meter
all the pins
Regards,
Matthieu
Could it be an array of transient voltage suppressor diodes/zeners ???
Clamping diodes?
- Franc Zabkar
Matthieu Benoit
Clamping diodes?
- Franc Zabkar
Hi Franc,
I thank you for your reply , I will inquire more
Matthieu
