Generating electricity from cell phone tower transmissions
Status
Not open for further replies.
oz93666
Dec 7, 2014
38
Someone I was communicating with online , happened to mention their bedroom was 30 meters from a cell tower.
I flippantly suggested he may be able to use the transmitions as a source of power , a coil of wire should be able to light a small led wired in series with it , perhaps a capacitor across the led to even things out .
Am I correct ? what would be a good coil diameter ?
14,487
probably not likely
you are not the first to have thought of this
the amount of power available for harnessing is absolutely tiny .... micro volts
oz93666
Dec 7, 2014
38
probably not likely
Power is measured in micro volts?.... Sure it would be tiny, but enough for a small led me thinks.
HellasTechn
Apr 14, 2013
1,579
WOW... I am really sorry to say that he is most likely to get cancer or leukemia rather than electrical power being so close to such tower.
Alec_t
Jul 7, 2015
3,821
I'd be surprised if there were much energy to harvest or cause health problems if you're that close to the tower. The antennae are highly directional in the vertical plane, so you'd probably be in a radio 'shadow'.
Seeing as the cell phone transmissions are microwaves, why not use them to cook your food?
14,487
no it wont unless you are standing right beside the antenna
... do you know how much a LED needs to work ?
oz93666
Dec 7, 2014
38
Just tried a small one from a 12v supply shows a light with over 1Mohm in series (2.7 voltage drop across led)
V=IR .....12-2.7 =I x 1000000 I= 9.3 micro amps P= IV = 9.3x2.7= 25 microWatts
So a small led will give light when consuming 25 micro watts (ten to the minus 6)= 0.000025Watts
14,487
but it's the micro Volts ;) ... try the same thing with only 25uV
it's not going to work as u need the ~ 2.7V minimum to get the LED to light up
oz93666
Dec 7, 2014
38
Voltage is not a problem ,you just increase the number of turns in the coil till you get it as high as you want.
14,487
that's not going to produce additional power ... as doing that is going to increase the resistance of the coil and negate any gains
since you don't seem to want to listen to reason
thread closed
Status
