Getting 24V from a 5V sensor output
ramussons
Jun 10, 2014
475
If you are meaning a 24 volt Pulse from a 5 Volt Pulse, I think a simple Transistor/FET amplifier should do the job.
What are the Sensor Output Specs? Pulse Frequency, Rise and Fall time?
Minder
Apr 24, 2015
3,560
A logic level Mosfet, a small one is the 2n7000 up to 200ma.
M.
  • FET2n7000.pdf
Minder
Apr 24, 2015
3,560
Incidentally if the 5v sensor is open collector then you would need a ~10k pull up resistor to use with a FET.
M.
