getting rid of gold on pcb
We have boards that inadvertently ended up with hard gold finish. As a
result we have 50 microinches of gold causing all kinds of headaches
at assembly.
We asked to have the extra gold stripped off but I was told it was not
possible.
Is there no way to dissolve the gold off? Otherwise we have to get
another batch made and they're expensive.
Mercury bath? Hot cyanide? Microtome? Have an immersion silver finish
over the gold!!! Argghgghgh anything!!
John Larkin
at assembly.
possible.
50 microinches is a lot. But you could have them hot-dip solder coated
and releveled, which would dissolve the gold and replace with solder.
That might work, but then the gold usually has nickel underneath...
What's the problem with the gold?
John
John
Hi John,
It's causing a lot of embrittlement as the gold dissolves in the
solder. As it is a 100 mil thick board with 12 plane layers and 6
signal layers, the board sits in the heat soak stage for a long time,
causing more gold to get dissolved.
The boards barely pass visual inspection of the solder joints, and
some 0402 ans 0201 parts just pop off easily.
The few bare boards we have left we want to somehow get them to work.
I'm trying to get the PCB fab to put immersion silver over the gold
but I haven't heard back from them. Perhaps they died laughing.
I like the solder idea, do you mean some sort of HASL ?? Or some sort
of wave process?
It's an unusual request I know.
John Larkin
Hi John,
What does one of those babies cost?
of wave process?
I was thinking of trying the regular HASL pass. I know that thin, like
10 uin, gold just dissolves in solder without much effect, and the
solder seems to stick to whatever's underneath, nickel usually.
John
TT_Man
John
I would have thought the same..... going through HASL should remove the
gold. Maybe you need to do it a couple of times..... not sure what the fab
plant will say about having their solder contaminated with gold though. But
doesn't the molten gold float on top of the solder?
John Larkin
It should dissolve nicely. At high gold concentrations, the
intermetallic is nasty brittle stuff, but diluted enough, the gold
shouldn't matter. I have no idea how long it might take to dissolve 50
uin of gold.
John
uin of gold.
John
Maybe I'll ask our assembly guys to put solder paste on the board and
reflow it, then send the boards to the PCB shop to do a HASL? Is that
the process with the hot-air knife and it'll blow away the excess
solder? Oh well look, it's Friday night already.
I'm off to pickle what few neurons I have left!
GoldIntermetallicEmbrittlement
uin of gold.
You're an idiot. The dissolution of the Gold is a BAD thing, dumbass.
It causes embrittlement, and no, after it gets above a certain amount,
it does not go away!
You should get a clue, before you spew.
John Larkin
Maybe you'd like to start over, and make a little bit of sense next
time.
John
D from BC
at assembly.
possible.
I have no experience in this area so I'll just rattle off the wacky
ideas:
1) Sandblasting (copper microspheres?)
2) Planar (as with lumbar)
3) Wet abrasive and lapping (mirror polishing)
4) Air blasting at 1063C (Au melting point)
(Cu melts at 1083C and Ni at 1455C..but PCB will burn)
5) EDM engraving
6) 3:1 HCL:HNO3 etching
7) Chlorine gas etching or Chlorine in solution
D from BC
Robert Baer
Gold will alloy slightly - around 2% if i remember correctly.
Robert Baer
ideas:
5) EDM engraving
D from BC
....and do not forget environmentally and people friendly Mercury as well
as acidic Cyanides...
D from BC
Wouldn't chlorine would be the choice toxin. If it gets loose, it's
heavier than air and will find something to react with. It's far from
being an inert gas and isn't found naturally in it's elemental form.
I'm guessing the resulting chlorine compounds are going to be more
friendly than mercury compounds or cyanide just sitting around not
reacting with objects.
If chlorine etching is used on the gold..it should be checked out what
temperature should be used.
The colder the temperature...the less reaction to copper.
D from BC
John Larkin
ideas:
5) EDM engraving
D from BC
You could probably rub the gold off with a scotchbrite pad and
household cleanser.
John
Martin Griffith
On Fri, 12 Oct 2007 11:35:02 -0700, in sci.electronics.design
at assembly.
possible.
I'd try Brasso, don't know what the US equivalent is.
http://en.wikipedia.org/wiki/Brasso
Martin
D from BC
household cleanser.
John
Yup.. Does sound like that'll work and perhaps worth a try..
Gold is a relatively soft metal. Using a pad that is just harder than
the gold but softer than the copper (or plating on copper) will help
reduce wear on the copper.
I know scotchbrite scuffs copper which means something in the
scotchbrite is harder than copper..
Household cleansers (ex Javex) contain chlorine compounds but I don't
know if that will react with gold.. (I'm not a chemist!)
However chlorine gas will. How fast..I dunno..
It's interesting, it takes only 1% chlorine to saturate water. Max
solubility is at 9.6C.. Anymore and it gases.
This can be a good thing too. I suspect chlorine has much more
reactivity with gold at 9.6C temp than with copper..
So.. chilled water saturated with chlorine and etch the board is my
guess... I have no idea if that'll work..but seems like a start.
Joke...Perhaps you could just plop the pcbs in a chlorinated public
swimming pool for a few days..
(I dunno if that'll work..)
D from BC
household cleanser.
Will your stupidity ever cease?
