getting rid of gold on pcb
ChairmanOfTheBored
Gold is one of the least reactive metals. The classic reactant is aqua
regia. I doubt that a bit of chlorine in water would have much effect.
And anything that eats through gold will go wild when it hits the
copper.
Gold is only second to Platinum where oxidation effects come in.
Both could stand a hundred years at ambient and not tarnish one iota.
They are more than a little immune to chemical attack as well.
Soldering involves heat. Dissolution of these metals during soldering
would not occur were it not for the heat involved. This is why one
should always solder with as low a temp process as can possibly be
tolerated while still achieving proper wetting, and good
micro-crystalline solder joint structure. High heat increases
intermetallic contamination in ALL cases.
Tim Williams
D from BC said:
Superior products that can do more than one hair, one eye or one ear..
:p
"Damnit, where'd I put my other pant!"
Tim
Michael A. Terrell
Robert said:
Brasso has been available in the US for at least 50 years...and is
still available.
1905
http://en.wikipedia.org/wiki/Brasso Apparently, it's one of the few
good things we got from England.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Martin Griffith
British Common Law.
Cheddar.
The magnetron.
Telequipment oscilloscopes. Just kidding!
There must be a couple more.
John
Windward Islands, marmite, trains, antibiotics, Thatcherism, Habeus
Corpus, 3 weeks paid annual vacations, punk, Jet engine, Bombe,
Martin
JosephKK
TT_Man [email protected] posted to sci.electronics.design:
I would have thought the same..... going through HASL should remove
the gold. Maybe you need to do it a couple of times..... not sure
what the fab plant will say about having their solder contaminated
with gold though. But doesn't the molten gold float on top of the
solder?
If it did not dissolve or go into suspension it could precipitate (to
the bottom, after all, it is denser than lead).
JosephKK
D from BC [email protected] posted to sci.electronics.design:
I have no experience in this area so I'll just rattle off the wacky
ideas:
1) Sandblasting (copper microspheres?)
2) Planar (as with lumbar)
3) Wet abrasive and lapping (mirror polishing)
4) Air blasting at 1063C (Au melting point)
(Cu melts at 1083C and Ni at 1455C..but PCB will burn)
5) EDM engraving
6) 3:1 HCL:HNO3 etching
7) Chlorine gas etching or Chlorine in solution
D from BC
Personally i think the choices are:
Abrasives, ala pink pearl erasers,
Lapping should be controllable enough,
Plasma etching.
JosephKK
Martin Griffith mart_in_medina@ya___.es posted to
What else would aqua regia disolve? BTW in WW2 one nobel prize
winner dissolved his medal in AR to stop the nazis getting it. The
gold was recovered after the war are re-cast into the medal, neat.
Martin
Most certainly any local metal.
JosephKK
Robert Baer [email protected] posted to sci.electronics.design:
is
still available.
Most metal polishes contain reducing agents to convert the corrosion
back to metal. Kinda defeats the purpose to expect it to remove
metal.
ChairmanOfTheBored
British Common Law.
Cheddar.
The magnetron.
The Beatles.
Pink Floyd
Alan Parsons Project
Genesis
Peter Gabriel
Kate Bush
The Who
A few more.
John Larkin
The Beatles.
Pink Floyd
Genesis
Peter Gabriel
Kate Bush
The Who
A few more.
William Shakespeare
Jane Austen
George Eliot/Mary Ann Cross
Anthony Trollope
E. M. Forster
P. G. Wodehouse
Dorothy Sayers
Patrick O'Brian
J. K. Rowling
Peter Hitchens
Mr Bean. Just kidding!
John
