I
ivan
- Jan 1, 1970
- 0
hi,
what is a good free capture and layout software?
Ivan
Ivan
hi,
Ivan
Christian Treldal said:Den Wed, 29 Nov 2006 10:28:01 +0100 skrev ivan:
Just took a brief look - very interesting. I have a few questions I didn't
notice while glancing through:
1. Is there any way to back annotate pcb changes to the schematic?
2. Does the pcb have full DRC?
3. Can it generate a BOM?
Regards,
Mike Monett
Mike Monett said:1. Is there any way to back annotate pcb changes to the schematic?
Yes.
Jan Panteltje said:What is wrong with Eagle for small boards and 2 layers?
http://www.cadsoft.de/
I believe the common objections are that it isn't free (as in beer) for
commercial usage and that some people really, REALLY want a piece of software
with the source code provided so that they can modify/patch it if they feel
like it.
Jan Panteltje said:So your second argument may be valid for somebody, but how many do you think
that are?
If I download a program, open source or closed source, I usually do that
because
I want to use it for something, not to 'improve on it' if in any way
possible.
As a company, the cost of time spend 'patching' (never mind time installing
even) is likely more then a brand new version of eagle.
So economics apply.
Jan Panteltje said:I have looked (downloaded geda whatever that package years(!) ago, and it
needed so many other packages, and with all that it still did not work,
so better use something that works.
Joel said:I believe the common objections are that it isn't free (as in beer) for
like it.
Did you use the cvs download, or the installer CD? The installer CD
has everything you need on one disk, and builds/installs it all for
you.
Andy Peters said:As it turns out, the free (as in beer) PCB software is worth exactly
what you pay for it.
Jan Panteltje said:I tried it from source. As I stated some years ago.
WTF is wrong with a tgz.
Probably will not work ;-)
RST Engineering (jw) said:Having started off life with the 1.2 version of EasyPC for DOS, waded
through Orcad, and wound up as a beta tester for Circuitmaker/Traxmaker 2K,
the problem with Eagle is that it is completely counterintuitive.
Ok, a lot has changed in the last few years.
The installer CD has all the tgzs you need, plus a script to build
what you're missing and install it - all in a separate directory, so
it wouldn't mess up your system.
So you can just build the tgz off the CD if that's what you want.
If not, we want to know. Ok, Stuart wants to know ;-)
: on it.
: Probably will not work ;-)
Let us know if it doesn't. If it fails, please report the distro you
are using along with including the Install.log file with your report.
If you just e-mail the developers a note saying "I tried your
installer and it failed. Why?" they will treat you like a two month
old sandwich found in the back of the fridge.
Have fun!
Stuart
Jan said:What is wrong with Eagle for small boards and 2 layers?
