good grief!
John Larkin
Yow!!!
I wonder where the gotchas are?
Last time I used them I wound up with some "interesting" power supply
sequencing problems.
Yeah, the ADI stuff does tend to have latchup quirks. We use one of
their octal dacs and it wound up bristling with schottky diodes to
keep it from suiciding.
But this is cool. Somebody could pop it in a box with some sort of pic
or a pc interface and have a killer R-L-C analyzer.
I wonder what it costs.
John
N
Nico Coesel
That's not really necessary. The device goes up to 100kHz. A proper
soundcard should be able to handle 90kHz / 24bit. You could make a
similar device using a standard soundcard or USB soundcard chipset if
the input circuitry needs to be a bit more fancy than a standard
soundcard offers.
John Woodgate
I read in sci.electronics.design that Nico Coesel <[email protected]>
soundcard offers.
I don't quite see how you could easily turn a sound card into a network
analyser.
Don Pearce
analyser.
I think it was a spectrum analyser he was talking about.
You can turn it into a network analyser, though and I have done it.
But it isn't easy making the directional bridge couplers. Probably
somebody makes them, but I wanted to do it for nothing.
After that the software for 12 term normalization and calibration
takes some writing.
d
Pearce Consulting
http://www.pearce.uk.com
N
Nico Coesel
analyser.
It has an input and an output. Generate a sweep on the output, sample
the signal accross the network, FFT the signal and you'll have a
frequency and phase plot of the network.
John Woodgate
I may be being dense, but it seems that the sound card is just producing
the sweep. To do the f-Z-phi analysis, you need a dual-channel FFT as
well.
N
Nico Coesel
well.
No, the soundcard should also be used as a sampler at the same time.
The PC does the signal processing and other math.
Joerg
Hello John,
It is cool. But most impedance analysis takes place well above the
100kHz limit. Mine are mostly 3-25MHz, or higher. When measuring
material properties it goes to a GHz easily, which is why that freaking
heavy HP impedance analyzer in the lab still has its place.
This AD chip seems to be geared towards the audio market. I wonder if
that is enough of a market in terms of size.
Me, too.
Regards, Joerg
Terry Given
Joerg said:
Hello John,
Me, too.
Regards, Joerg
It might be pretty good for a control system loop analyser. As long as
Fsw < 1MHz or so, 100kHz is fine. The real problem there of course is
getting the signals in and out without killing anyone :)
Cheers
Terry
Jonathan Kirwan
An announcement page I saw put it this way:
http://www.eeproductcenter.com/printableArticle.jhtml?printable=true&articleID=60406316
"All devices are currently sampling with production quantities of the
CDCs (AD7745 and AD7746) and the IDCs (AD5933: 12-bit, 1
Megasamples/s; and AD5934: 12-bit, 250 Kilosamples/s) slated for May.
The AD7747 CDC is currently sampling with production quantities
planned for August. The devices are available in small 16-lead TSSOP
and 16-lead SSOP with prices ranging from $4.60 to $4.95 (CDC) and
$4.35 to $6.65 (IDC) per unit in 1,000-piece quantities."
I'd guess this means the AD5933 is on the high side of the IDC's, so
$6.65 in 1000's.
Jon
Joerg
Hello Jonathan,
$6.65 in 1000's.
That would be a good price. But since the chips are for audio range apps
I am not so sure that there is a large market.
Non-destructive testing could be an additional market for these.
Regards, Joerg
Similar threads
Replies
30
2K
Chieftain of the Carpet Crawlers
Replies
9
3K
Andreas Tekman
