Guitar Amplifier
blacksheep1
Feb 21, 2004
15
Hi :)
I want to build a guitar amplifier, but i haven't found any useful schematics yet... I want it to be powerful, maybe 100 Watt if its possible, it has to be a clean pre-amp (which means: no distortion), low-noise as possible (no hiss) and a 3-band graphic equalizer (low, mid and high-controls), look at my drawing.
I'm a newbie in audio electronics, so i don't know that much about op-amps, transistors... you name it :)
If you think you know much about it to help me creating some schematics, you are very welcome to post in this forum or to my mail-adress: peter(@)gawis.dk
darrins
Jun 29, 2004
82
Try these sites:
http://www.ax84.com/home.html
http://freespace.virgin.net/vyse.co/build_your_own_amp.htm
http://www.duncanamps.com/brewlink_amps.html
Good luck. :)
Darrin
audioguru2
Apr 6, 2004
12,022
Hi Darrin,
Toobs and output transformers?
Yeah, I remember those.
Some transistor amps have vacuum tubes glowing just for show, since their tubes aren't connected to the amp's circuit!
blacksheep1
Feb 21, 2004
15
Thanks for the links, but it seems like its only tube-amps, and thats not what i'm interested in... :) hehe...
Maybe somebody have some schematics of a (very) simple preamp with TL072 or similiar opams. I think, it could help me to find out how to work with opams...
ante1
Jan 24, 2004
4,136
blacksheep,
Here is all you need !
http://sound.westhost.com/projects.htm
Ante ::)
blacksheep1
Feb 21, 2004
15
Ante, I've already tried building the pre-amp - the problem is, that the sound isn't clean. I wanted a clean pre-amp :) But maybe i could use the power-amp schematic... Thanks :)
Really nice site, EDY, but it's still tube-amps :-[ hehe
But, thanks for helping. I would really like some beginner-guides to build pre-amps with op-amps and/or transistors. Somebody in this forum must know something about that :)
darrins
Jun 29, 2004
82
Sorry about the links to tube amps. :-[ I just did got these links from a google search and didn't read all the content.
You may be able to find a good amp on eBay. Sometimes it's cheaper to buy than build. I certainly got a good deal on my oscilloscope. Not that I could build an oscilloscope. ;)
Hope you're not building one of those giant wall amps from "Back to the Future". Your neighbors might get upset.
Cheers.
Darrin
darrins
Jun 29, 2004
82
blacksheep,
There are a couple of amp projects on this site that use more "modern" technology. ;D
http://www.discovercircuits.com/A/a-audioamp.htm
Darrin
audioguru2
Apr 6, 2004
12,022
Hi Blacksheep,
Which preamp did you build, and please explain what in its sound sounded "dirty". Hum or buzz, distortion?
blacksheep1
Feb 21, 2004
15
I did build the pre-amp of this project:
100W Guitar Amplifier Mk II
http://sound.westhost.com/project27.htm
The problem was that almost nothing was comming out of the speaker unless i was turning up the gain-control, and then I got distortion. The Volume-control was as high as possible... then i looked on the project-site again, and changed some resistors but it didn't work very well....
I think its best if I start with a simple schematic... i think the dual opamp TL072 should be fine, but I don't know much about op-amps... so I need some help :)
I explain: I don't need big complicated schematics of already build guitar-amps, I more need some beginner-info about building pre-amps with op-amps (or maybe transistors)
Thanks for helping me :) - But I need more help :-( , so everybody is welcome to post some info :)
ante1
Jan 24, 2004
4,136
Blacksheep,
Maybe your input signal is to weak?
Ante ::)
audioguru2
Apr 6, 2004
12,022
Blacksheep,
Did you have your speaker connected directly to the output of the preamp? Sorry, but I had to ask since it would cause your problems.
If the preamp connected to a power amp, does the power amp have a low input impedance? (I hate emitter-followers!)
blacksheep1
Feb 21, 2004
15
The speaker was connected through a power-amp... I don't know anything about the impedance :-( but I still think it's the way that the preamp is made... you know, some guitarists likes distortion, but i want a clean pre-amp :)
audioguru2
Apr 6, 2004
12,022
Hi Blacksheep,
Did you remove the "distortion-diodes" and emitter-follower from the preamp's output, as recommended in the article?
blacksheep1
Feb 21, 2004
15
No i didn't remove the diodes... maybe thats the problem ::)
What do you mean about an emitter-follower? I've heard about it before but i don't know what it means...
But thanks... i'll try that very soon :)
audioguru2
Apr 6, 2004
12,022
Blacksheep,
The article tells what to remove under "Bass Guitar, Electric Piano".
That darned emitter-follower is the transistor. It is thrown out too.
When the diodes and transistor are removed (plus changing a few things), then your distortion will vanish.
EDY2
Jul 14, 2003
85
I've builded this simple preamp with my friend for his guitar. It is more less just a simple active-out for guitar 'couse it is connected directly to magnet pickup. It worked like a charm. No distortion and clean sound. Best thing is it is as simple as it gets. I posted pictures below but try this link also for a little different wersion of the same pre-amp
http://www.till.com/articles/GuitarPreamp/index.html
Cheers
