Can't Identify Components in Old Guitar Amplifier
Jsprite7660
Oct 31, 2023
7
I'm replacing some components in my guitar amplifier but I can't figure out what these two things are. Attached are photos of both. I think they're capacitors but am not sure. There isn't any print on either of them.
I could not find any schematics for this amp as it is an obscure Webster Electronics amplifier.
Let me know if you have any info on these. Thanks all!
roughshawd
Jul 13, 2020
618
That's a really old amp. Can't remember that far back. I think I tested them for resistance and they didn't do anything... I know the store owner was really p.o.'d and told me to just leave it alone... What kind of amp?
kellys_eye
Jun 25, 2010
6,512
They both look like resistors to me. The red one certainly is. The value is read from the colours - body, tip, spot. So body red (=2), tip (orange?) =3 and spot (brown?) = x10 multiplier. Value is therefore 230 ohms.
The colours may have changed over the years so the above is just a guess. If you have a test meter you could just measure it. They have a 10% tolerance (the silver band) so the value can vary 'a bit'.
A simple resistance test on the green one will reveal whether it too is a resistor - else it is a capacitor! I still think 'resistor' although it has been badly overheated.
danadak
Feb 19, 2021
1,104
Great ref material https://alliedcatalogs.com/index.htm
Carbon R's in old gear usually out of spec, especially ones that run hot, such as Cathode and Plate R's,
power supply V dropping R's, screen grid R's.
Regards, Dana.
kellys_eye
Jun 25, 2010
6,512
Cathode resistors commonly fail due to capacitor failure - change the capacitors first. Then change the obviously overheated resistors. Unless the remaining resistors read well outside their tolerance I'd leave them alone.
Jsprite7660
Oct 31, 2023
7
It sounds amazing, t's a Webster Electric (From Racine Wisconsin) amplifier. It's probably an early 60's I feel.
Jsprite7660
Oct 31, 2023
7
Sounds good will do. I was planning on checking the filter caps mainly and then came across those and was confused. Thanks!
Jsprite7660
Oct 31, 2023
7
Cool, thanks a lot!
