guitar fuzz effect
jojoph_86
Mar 11, 2007
5
i have a project about guitar fuzz effect, i want to know how the guitar fuzz effect work and what is the cause of fuzz efect and how this fuzz effect was created...please help me....i would really accept if someone helps..
thank you..
ante1
Jan 24, 2004
4,136
I believe we need to see your circuit since there is several ways to obtain fuzz (distortion).
audioguru2
Apr 6, 2004
12,022
Hi Jojo,
Aren't you Josh from the other website forum? You didn't answer my reply there.
Is this the fuzz effect circuit you are talking about?
audioguru2
Apr 6, 2004
12,022
Hi Josh,
Severe distortion produces fuzz.
The diodes are in the negative feedback path of the opamp. The opamp will operate normally and will have a very high gain when its output level is less than about 1.2V peak-to-peak. When the output level tries to climb above 1.2V peak-to-peak then the diodes conduct and suddenly reduce the gain so that the output level cannot exceed 1.2V peak-to-peak which produces severe distortion. The output becomes slightly rounded square-waves.
jojoph_86
Mar 11, 2007
5
yes, i am josh from the other website forum..yes this is the circuit diagram..please explain this circuit diagram and how does it work..by the the way, thanks for the reply in the other website forum..thank you in advance..
jojoph_86
Mar 11, 2007
5
thank you very much for the information..it could help me a lot with this information..thank  and more power..may i ask if you could me in my other topicss soon..
thanks..
josh
aqmas
Mar 20, 2007
10
hello, can someone explain where plug loudspeakerin this circuit? thankyou.
Ps. Sorry I can't write good, without mistakes, sorry
audioguru2
Apr 6, 2004
12,022
A loudspeaker must be driven from a power amplifier. This fuzz effect circuit can be the input to the power amplifier. The fuzz effect circuit has an opamp that has a very low power output.
aqmas
Mar 20, 2007
10
thankyou, I understood  ;)
