Music Man said:
Seeing the guitar pickup is a magnet,it produces an A/C current.Yes?
Yes. The vibrating string in a magnetic field changes the induced current
in a coil.
Does the Preamp input turn it into a DC current?
No, that would make it impossible to hear. The guitar preamp has two
important functions. To amplify the signal, and to convert the high
impedance to a lower impedance. That simply means making it stronger,
both voltage-wise and current-wise.
How does the input deal with the voltage supplied,and does the
impedance change
when the signal declines.
The impedance of the guitar pickup is always high, no matter how strong
the signal gets.
Also in a guitar preamp why would you earth if the amp had earth
problem,wouldn't
it go to the earth plate in the guitar,or is that a new thing.That is
,did old electric guitars have no earth?
Not sure if I lost you there, but the guitar pickup has two connections,
two ends of the coil which is wound around one or six permanent magnets.
One end is usually connected to the metal parts of the pickup and should
be used as the ground side of the pickup. Connect it to other grounded
metal parts in the guitar. This reduces noise from outside.
Sometimes guitarists want to connect one pickup backwards and mix it with
another pickup, to create more harmonics. Then they ignore this
precaution and use the ground side of one pickup as the signal side and
vice versa. So it is not necessary to connect a guitar pickup correctly,
it is just the preferred way to do it.
Here is a very popular guitar effects box, the Ibanez Tube Screamer.
http://www.generalguitargadgets.com/diagrams/ts-808_sc.gif
Look at the transistor Q1, it is the preamp which converts the guitar
signal from high to low impedance. In this case the next stage is an op
amp so no amplification is needed in the first stage.
Here is another input stage which both fixes the impedance and gives
amplification, in the Q1 transistor.
http://www.generalguitargadgets.com/diagrams/bmpsc.gif
Here is a web page with a lot of information about guitar preamp circuits
built with transistors of different types:
http://www.muzique.com/lab/lowvolt.htm
In all these links you can go up one or more directories and find a lot
more guitar electronics information and schematics.
