Halogen projector bulb for American DJ effect burns out to soon
roughshawd
Jul 13, 2020
618
The bulb is a specialized 2 pin mini-projector style bulb 250w. Is there a good replacement that will last longer than a few hours?
kellys_eye
Jun 25, 2010
6,512
Is there a manufacturers spec on the bulb? They usually state a minimum lifespan but with most such devices it's heat that does the damage so ensuring the fan (assuming it has a cooling fan?) is working and no filter is blocked etc you could add a bigger fan??? Physical stress is also a 'killer' so no moving the lamp when hot or as it cools etc.
The usual precautions re handling (no fingerprints on the envelope etc) are observable etc.
The only other thing I know is that after-market devices, whilst supposedly saving you a few $, don't last as long as the OEM stuff - if you're using after-market that is?
You might have some success Youtubing for LED conversions if that model supports it.
roughshawd
Jul 13, 2020
618
Thanks. The projection system in the US have always been "dead already" devices.
