dave vanhorn
- Jan 1, 1970
- 0
I need a little advice.
I'm building a design that was done using an NPN bipolar in a hartley
configuration, with a ferrite tuned coil, running between 700kHz and
1.1MHz
There are four identical oscillators, built and used as two pairs.
Schematic is at http://www.paia.com/theresch.htm
It's having several problems, but I'd like to fix them without a major
redesign.
First, is stability. The osc drifts a fair bit.
This osc is being mixed with another identical osc, and I was hoping
that component thermal variance would be minimized, but I can actually
detect blowing on the circuit from 3' away..
The osc is also hard to tune, just a tiny twitch on the coil and
you're past the proper point. I'd like to tame that down to even as
little as 1/8 or 1/4 turn.
The other, is some odd behaviours that I'm seeing.
1: jumps in frequency, maybe 10-400Hz. These occur at random times,
and are not "wobbles" so much as discrete steps.
The input voltage is shunt zener regulated, and the zener is quite
cool.
I may need to increase current into the zener to make it more stable,
but I don't think this is the problem.
2: When the two oscillators are near the same frequency, I can see
large changes in the waveforms of both oscillators, and in the mix
product.
I can email a scope capture to those interested.
The mixer is a simple pair of diodes, and I am feeding in the output
of the oscillator coil tap, through 2.2k. I've tried as high as 10k,
which reduces the level, but does not particularly help. Note the
mixers are not implemented as shown in this schematic, they use a pair
of diodes only. I've even gone as far as to use matched pair diodes
here.
I also tried 2N4401 transistors, but no noticable difference.
The inductor is a mouser part, 42IF110, 760 kHz
I added an additional 0.01uF across the base bypass cap, which made
the control wiring relatively immune to "hand effect", but had no
effect on these other problems.
The board layout looks good, and the board is mounted over a ground
plane, with rigid standoffs, and wiring is taken away from the
oscillators, not laying over them..
There are no antennas attached, so we are just talking circuit issues,
nothing beyond the PCB or power supply should be a problem.
1.1MHz
redesign.
cool.
product.
here.
