I wondered if you might reply to this thread. Part of the welding I do
in my shop is TIG welding and I do use helium sometimes. I also have a
laser tube, the bar scanner type, that doesn't lase anymore even
though the power supply is fine. If I was to put the tube in a
pressurized vessel of helium do you know how much pressure and how
long a time it would take to refill the laser tube?
Do you have an idea of the make and model of the tube? Most of these
are hard-seal and never suffer from He depletion. And even those
that have Epoxy seals often leak air in more quickly than He out.
However, you have He and nothing to lose, so put it in a bag of He
at atmospheric pressure for approximately 1 day per year of age.
So, if it's about 20 years old, try 3 weeks. Remove it and test
periodically. If you go overpressure on He, there's no way to get it
down quickly.
sam | Sci.Electronics.Repair FAQ:
http://www.repairfaq.org/
Repair | Main Table of Contents:
http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ:
http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites:
http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
