michael1978
- Mar 17, 2012
- 388
- Joined
- Mar 17, 2012
- Messages
- 388
Hello, can somebody teach me, what i need to connect an am receiver to arduino,
what do i need to do? thnx
Howsabout you tell us what YOU want to DO? Then someone here will determine how "to connect an am receiver to arduino" if that seems to be an appropriate solution to whatever it is you are trying to DO.
o sorry , yes i wil like to control the tuner(station select) of the receiver from arduino. can you help me pleaseSpecifically.
We do not have glass balls to read your intention.
- do you want to take the receiver's audio output and read it from the arduino?
- do you want to control the tuner (station select) of the receiver from the arduino?
- do you want to control the audio output of the receiver (volumen, bass, trebbel controls...)
- which receiver do you want to use?
We can help, but as @Harald Kapp said in post #3, most of us do not have crystal balls or the necessary psychic skills to divine your intent.... i wil like to control the tuner(station select) of the receiver from arduino. can you help me please
Hi, i know how to do it , i have enough examples in internet, when they are ready, just to programming, but i will like my am receiver to connect, i make self my am tunerWe can help, but as @Harald Kapp said in post #3, most of us do not have crystal balls or the necessary psychic skills to divine your intent.
For starters, do you have a particular radio (manufacturer name and model) you want to tune with an arduino? Why do you think an arduino is suitable for the purpose of tuning a radio receiver? Do you have a project in mind, or is this just a "what if" investigation into the possibility of using an arduino to tune a radio receiver?
Some of us here don't mind working on "pie in the sky" problems, but others feel it is a waste of time if nothing concrete or practical is resolved. It's nice to know in advance which direction this thread is going to take before committing a lot of time to it.
For whatever reasons, many original posters feel it is unnecessary to provide in-depth information of what they are trying to DO. The result can be weeks of back and forth questions as we try to pry out sufficient details to provide a reasonable solution. Please don't be that kind of poster: tell us up front, in as much detail as possible, WTF you are trying to DO. A few electrons may be inconvenienced by whatever words appear on our screens, but no trees will be destroyed... And, if we don't care to read everything we see, there is a little key on our keyboard that will automagically delete it.
What then is the question, I wonder?Hi, i know how to do it
Then you will have to provide the means for controlling the frquency selectin in a digital way. How you do this depends largely on the way you build the tuner. Some off the shelf tuner modules come with a built-in digital tuning capability. Other types of tuner may need an analog control voltage etc.i make self my am tuner
Ah So i have to make digital way, thank you very much now i understandWhat then is the question, I wonder?
Without us knowing (from you) how the frquency control of the tuner is done we can by no means support you how to achieve the necessary kind of control.
I doubt that you understand enough. @Harald Kapp offered you two methods "for controlling the frequency in a digital way." The arduino is a digital computer, so its output will be derived from digital instructions, but that does NOT mean the output has to be digital.Ah So i have to make digital way, thank you very much now i understand
rely i just need these step and after to programming in arduino. i told that i take itYou should have stated up front and immediately that this circuit was copied from this website. I hardly think it is worth the effort, but to interface this circuit to an Arduino you will need a digital-to-analog converter and one or more varactor diodes, such as this one, an SVC236-TB-E from ON Semiconductors and available from Mouser. You wire two or more of these varactor diodes in parallel and connect them in parallel across the tuning capacitor, VC1, in series with a largish-valued DC-blocking capacitor. You will then need to reverse-bias the varactor diodes with a separate, isolated, DC power source whose output voltage is controlled by the digital-to-analog converter connected to the Arduino. Easy-peasy, then just add some software... er, sorry, a sketch... as software is called in the Arduino world.
thank you very much you help me a lot, have a nice wekendrely i just need these step and after to programming in arduino. i told that i take it
from internet this am receiver
oo sorry one more time me, you mean to add to varactor extra dc power that output is digital to analog converter, ok, but how many varactor do i need to use 2 of 3 of more, and how much is for example the dc blocking capacitor size, and where to take output? sorry Mr that i ask you su much because is very important to me THANKS.You should have stated up front and immediately that this circuit was copied from this website. I hardly think it is worth the effort, but to interface this circuit to an Arduino you will need a digital-to-analog converter and one or more varactor diodes, such as this one, an SVC236-TB-E from ON Semiconductors and available from Mouser. You wire two or more of these varactor diodes in parallel and connect them in parallel across the tuning capacitor, VC1, in series with a largish-valued DC-blocking capacitor. You will then need to reverse-bias the varactor diodes with a separate, isolated, DC power source whose output voltage is controlled by the digital-to-analog converter connected to the Arduino. Easy-peasy, then just add some software... er, sorry, a sketch... as software is called in the Arduino world.
sorry can i send you my ltspice file, wich i maket that am receiver, maybe you can change selfYou should have stated up front and immediately that this circuit was copied from this website. I hardly think it is worth the effort, but to interface this circuit to an Arduino you will need a digital-to-analog converter and one or more varactor diodes, such as this one, an SVC236-TB-E from ON Semiconductors and available from Mouser. You wire two or more of these varactor diodes in parallel and connect them in parallel across the tuning capacitor, VC1, in series with a largish-valued DC-blocking capacitor. You will then need to reverse-bias the varactor diodes with a separate, isolated, DC power source whose output voltage is controlled by the digital-to-analog converter connected to the Arduino. Easy-peasy, then just add some software... er, sorry, a sketch... as software is called in the Arduino world.
yes if it is possible ;-)You need sufficient varactors to provide the required capacitance, and provide a voltage swing sufficient to vary the capacitance through the required range.
You have basic idea.
Would you like us to build and test a prototype after we design it?
Sure, almost anything is possible with sufficient time and the money to pursue it. How much of both are you willing to invest? This is not a teaching forum. It is a discussion forum.yes if it is possible ;-)
WTF would I want your LTSpice file? It's your project, not mine. And the LTSpice simulation for that circuit is readily available on the Internet at this link that I previously provided.sorry can i send you my ltspice file, wich i maket that am receiver, maybe you can change self
Thank you this site is very good, ohhh i learn i forget, thanks for helping, i search al long to find radio receiver to connect in google, but i did not find, only with their module, and arduino with their modul i find easy...because i find a lot how to make receiver, BUT THIS WAS SOMETHING SPECIAL TO ME, TO CONNECT AM RECEIVER TO ARDUINO. i cant find nowhere, only arduino with their module(chip), wich is ver easy, but anyway thank youSure, almost anything is possible with sufficient time and the money to pursue it. How much of both are you willing to invest? This is not a teaching forum. It is a discussion forum.
It has often been observed that God helps those who help themselves. That meme applies to posters seeking help here at Electronics Point. As a hobbyist forum, we help those who help themselves. You help yourself by learning how the circuit you copied from the Internet actually works, determining what its advantages and disadvantages are, determining whether it is even suitable for your needs.
After doing all of that, learn about varactor diodes and how they are used as variable capacitors. Understand why a DC blocking capacitor is needed to add varactor tuning diodes to your circuit, and what its value should be. But before that, learn some electrical theory, such as how the three basic passive components (resistors, capacitors, and inductors) work. Learn the math skills needed to perform circuit analysis. Learn how to apply Ohm's Law and Kirchoff's Laws to analyze circuit behavior. Make Google your Best Friend as you search for answers. Take free online courses. Don't be satisfied with "monkey see, monkey do" solutions.
I am not going to provide you with a free "canned" solution, although there are other websites and forums that attempt to do that. If you are satisfied with such, try visiting them. Start with this one. If you want to be an electronics hobbyist, put some effort into learning electronics. We'll help if we see that you are trying to help yourself. Otherwise, it appears to me that you are just another "drive by" poster looking for quick answers. BTW, your English, spelling, and grammar are terrible. Put lots of effort into improving that first.
