Hello, i need a little help with inductor used in jfet
michael1978
Mar 17, 2012
388
Hello can somebody help, what do the inductor L1 is to stop high frequency of wat, this is circuits
duke37
Jan 9, 2011
5,364
This is an oscillator using Q1 and Q2 as the feedback circuit. It is a type of multivibrator.
The frequency is determined by the tank circuit consisting of L1 and capacitors to earth at each end. CV is variable to trim the frequency to the desired output frequency.
The frequency can be roughly calculated from the equation F=1/(2*pi*srt(L*C)). Take C=38pF. The actual frequency will also depend on stray capacitances and inductances.
michael1978
Mar 17, 2012
388
Thank you very much…..Have a nice wekend. ;)
michael1978
Mar 17, 2012
388
O sory, can you just tell me where discharege
O Duke i have some question, i search on the internet, to find how the circuits works, but i did not find something like this………..is possible to describe how work the circuit please
duke37
Jan 9, 2011
5,364
To make an oscillator, the loop gain must be more than one. Normally, as here, the gain is much more than one but it is reduced when the amplitude reaches a limit. This high gain can generate high frequency parasitic oscillations which are not wanted. The 18Ω resistor will damp the high frequency circuit to give a loop gain of less than one. Resistors or lossy ferrite beads are used in critical positions which will depend on the devices used and the actual layout.
michael1978
Mar 17, 2012
388
Duke i will like just to know how charge and discharge L1 and C just that i want to know thnx
14,317
This question makes absolutely no sense in this contect. The circuit is an oscullator and C1 L1 will be "charged" and "discharged" alternatingly with a frequency of approx. 9 MHz.
michael1978
Mar 17, 2012
388
Thats is right LC charge and discharge i know, but i never see something like this circuit, but like Duke say, after is feedback Q1 thrugh Q2, because i never use fet transistor, for that its new for me. and Q3 get signal from Q2 right? of not…..and Q3 is output?:(
duke37
Jan 9, 2011
5,364
In #6 you explain just how ir works. I do not see how to explain it further.
Q3 is fed AC through the 120pF capacitor. Q3 is a source follower where the transistor will give the same AC voltage out but be capable of higher currents, sufficient to drive 50Ω.
michael1978
Mar 17, 2012
388
Ah for that i ask , do i know of not., THANK YOU DUKE:), have a nice day….
