help "EtCHING technique"
wacky
Oct 12, 2006
6
hello pep's
  Do you have techiniques in making a fine and cool PCB etching. plss give tips and method on how to make it pls!.. hope it is not to expensive.....
thankssssssssssssssss
Reptilian Feline
Nov 29, 2006
36
One way is to print out the PCB-design using a lazer-printer and iron it on. Several pages popped up when I googled.
jgeidl
Feb 24, 2006
35
Take a look at the group linked below.  You will have to join but it is free and they don't bury yoou in spam.
http://tech.groups.yahoo.com/group/Homebrew_PCBs/
Jim
Herman the German
Sep 1, 2006
179
:eek: The most simple way is just dumping your PCB into irontrichloride in a flat bowl.
Etching accelerates with a little mechanic help. This can be done by causing the liquid to make small waves on the surface. Advantage: You can see the progress and take out the PCB early enough to prevent under-etching. Disadvantage: You have to do this for about 30 minutes.
2. Use a container high enough not to spill the chemical stuff. Then use a rotary type aquarium pump and a spray bar (Poke little holes into a plastic hose) and spray equally over the entire board. Either oscillate the board or rotate the plastic hose at moderate speed to cover the sprayed area all over your board. That works faster than the above described method.
HtG
