help i.f transformer how to make one
michael1978
Mar 17, 2012
388
hello everybody
please can somebody help me, explain me, i search on the internet how to build one , but i dont understand
how to make if transformer
i dont know nothing about transformer, i just know that they us to step up or step down voltage
i am a begginer
thnx
dorke
Jun 20, 2015
2,342
As a beginner you need not and should not build a transformer !
All you could ever need may be bought cheaply.
In fact professionals rarely build a transformer,they buy them as well.
Minder
Apr 24, 2015
3,560
Yeah, it is hardly worth winding your own I.F. txmr, you would need to know the intermediate freq for one, and type of device/stage on the in and out side.
kellys_eye
Jun 25, 2010
6,512
I think I've seen some articles on winding your own.... it's not easy but equally not impossible either. It IS, however, a lot of trouble!
Here's one from a few years ago:
http://www.rfcafe.com/references/radio-craft/if-coil-design-april-1932-radio-craft.htm
What is your specific application? It's often easier to make crystal filters of specific bandwidths than do it using transformers unless you're after some 'expensive' centre frequency (455kHz crystals are rare and expensive for example) and if it's for a receiver there are plenty of opportunities to choose your own i.f.
michael1978
Mar 17, 2012
388
maybe you are right, butttt beter to learn self to do experiments why not, thnx
michael1978
Mar 17, 2012
388
this i still dont know, i try to build one radio receiver
michael1978
Mar 17, 2012
388
i am reading the book, build you own radio transistor, is very good book to learn to build radio receiver, but i did not finish the book.....
Miguel Lopez
Jan 25, 2012
255
michael1978 said:
yeh excatly, very beatiful guide, do you know some other own like this site over if transformer, thank you
I'm pleased to help. You can contact Harry Lythall by e-mail at http://www.sm0vpo.com/
Some time ago I downloaded an article from his blog about IF transformers which I consider very interesting. Saddly I can not find this article in the web right now.
The name of the article is:
DIY IF CANS FOR VALVES
duke37
Jan 9, 2011
5,364
You will need to decide the purpose of the transformer. Is it to change the impedance or to provide a tuned circuit or both. The traditional IF transformer has an input winding and an output winding, both tuned with a capacitor and critically coupled together.
The transformers are often wave wound to reduce coil capacitance - not easy to do.
The wire may be Litz which is multiple very thin strands, all of which must be soldered.
If you want to change impedance at a high frequency, then the transformer can be wound on a ferrite toroid.
You need to specify frequency, bandwidth, power and size. If you can find one with the characteristics you want, it may be possible to copy it.
Reset
Oct 25, 2017
6
How does that design result in an i.f transformer? Where is the secondary?
I wound a 3" coil and a 1" coil. It was used at the IF port of a Double Balanced Mixer to pick up the 1600Khz IF that feed it to an AM receiver which was tuned to 1600khz using the AM receiver as the IF for a dual conversion set.
Reset
Oct 25, 2017
6
michael1978
Mar 17, 2012
388
