Finally found the problem. Two of the 32 backlight LEDs behind the LCD screen were bad. Changed the whole set and the TV is fixed. Thank you all for your help and patience.
.5 % is probably not right since most consumer products do not use such small tolerance components. That 5th band could be a MTBF code. The 4th band is hard to distinguish between yellow or gold. Look at some of the other resistors similar to the one in question and measure to determine what the color bands and their positions stand for. A schematic is the only way to go to determine values accurately.
