Help identifying connector
zephed666
Jan 22, 2020
5
Hello:
I am a total newbie with electronics and am trying to identify the connectors used for a wire that corroded so I can replace them. The wire is 22 AWG stranded.
I have attached a picture of the plastic connector as well as the metal connection that goes inside of it. It is a two pin connection with a little clip on it to lock it in palce...
Any help would be greatly appreciated...
Thank you!
zephed666
Jan 22, 2020
5
Hi and welcome :)
they are very common
Molex are one manufacturer that make that style of connect
look on digikey and similar places
Is there a specific name for these connectors or they're just common connectors?
bertus
3,868
Looking at the connector, it more looks like burned.
It could be due to a to high current or a loose connection.
Bertus
zephed666
Jan 22, 2020
5
Bertus
Yeah, Took it apart and the wire is corroded inside. The burned side actually has continuity still the other one does not.
Just want to replace since it was in a wet area. Bad design if you ask me. Want to run a longer wire to keep out of the wet area...
Hello:
Thank you!
Could be a mini jst.....
https://www.ebay.com.au/p/260272565...MI0vK4yKiY5wIVkjUrCh2foQa-EAQYBSABEgK1tvD_BwE
