Help identifying mosfet
Gintby
I've been asked to look at a Genius G-12-060 12V 600W inverter
(http://www.atlantasolar.com/product_info.php/name/G-12-060 12V%
20600W/products_id/416).
All 6 of the mosfets(?) have failed short circuit.
It may not be worth the effort of actually repairing; but just for
giggles I've removed them and I'm trying to find a suitable replacement.
The devices are TO-220 are simply are marked:
F N334AN
The F doesn't look like a Fairchild F, but it appears to be seperate from
the part code.
Anyone have any ideas? or any guesses as to what the missing suffix could
be?
Meat Plow
F N334AN
the part code.
be?
If it's an N channel device it would probably be fine to replace it with
Fairchild part number RFP45N06. Specs are 50 amps at 60 volts and they are
just a buck or two each. Not knowing jack about your device brand but
working on others I've repaired were all N channel enhancement mode fets.
Gintby
with Fairchild part number RFP45N06. Specs are 50 amps at 60 volts and
they are just a buck or two each. Not knowing jack about your device
brand but working on others I've repaired were all N channel
That's the big *if* though. I'm not even sure they are mosfets....(but
I'd be surprised if not).
